what does a 3.4l need to run 14's???? - FirebirdV6.com/CamaroV6.com Message Board
  • what does a 3.4l need to run 14's????
    i have a 95 3.4 auto camaro.
    i have a list of mods as long as my arm and im running 15.2 the most significant of which is my 85 shot of nitrous and 3.73 gears.
    1999 White Ford SVT Lightning.<br /><br />Hoping to dyno @ 450hp/550tq by the end of \'04.
    up the nitrous shot and remove your audio equipment and some other stuff for weight reduction
      seats and speakers were removed and my reaction times were both .6 something. what did the ones whove run 14's do?
        also, the mods in my sig are about 50% of what ive done to the car, no internals though. the nitrous and gears are still the major players.
          sorry but your reaction time could be perfect .500 and your et will not change, reaction time has absolutely nothing to do with 1/4 et or mph, the only way r/t matters is if your bracket racing
            Suggestions:
            1LE aluminum driveshaft - drop 15 lbs of reciprocating mass.
            Did you change the torque converter? Higher stall should help, as long as you can get it hooked up.
            Do you have tube headers? May cut a little bottom end but should help the 3.4 take advantage of your exhaust system improvements/cutout.
            Race in the coldest low humidity air you can get. My best times typically come in November.
            1995 Camaro M5 3.4 Quasar Blue Metallic with T-tops.<br />K&N, Jet Stage II chip, Z28 exhaust, 1LE aluminum ds. Need more power!<br />Next: Auburn posi<br />1976 Pontiac Trans Am. Street driven. Has low compression 350 Chevy runs 12.81 @ 104, 1.73 60\'
              Rip off that body kit. Stall the car up as high as you can without spinning and don't be stingy on the juice.
              Josh-
              \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
                Actually the body kit doesnt add enough weight to make an et difference, actually i ran .11 better with my body kit, go figure
                Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                  <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
                  Actually the body kit doesnt add enough weight to make an et difference, actually i ran .11 better with my body kit, go figure<hr></blockquote>
                  mahe ricers are right? I doubt the body kit will affect it that much.
                  torque converter will help ya and if you have the stock drivesahft get an lt1 or ls1 driveshaft. Which ever one you can afford.
                  As for upping the shot make sure you are getting enough fuel to support it.
                    As close as you are, a few hundred pound of weight loss should get you there, maybe a little more nitrous and you would be in the 14?s for sure. I see you have a big set of corvette grand sport rims, seems like overkill but I bet it looks killer. A set of weld 15x8s? draglights w/ skinnies in the front and maybe wrapped in Nitto?s would help.
                    I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
