About how much difference in the 1/4 between 15" rims and 16" rims? - FirebirdV6.com/CamaroV6.com Message Board
  • About how much difference in the 1/4 between 15" rims and 16" rims?
    If i had the stock 16x8 salad shooters with mickey thompson 26x10.5x16 et streets and i had 15" rims with 26x10.5x15 et sreets would there be a noticeable gain with the 15s over teh 16s, or would it only be maybe at most.1 in the 1/4? Would i have a better et with 26x11.5 over 26x10.5? And my last question is would i have a better 1/4 et with 26" or 28" or 30" would 28" and 30" be to big and just slow me down? I have just about every bolton with powerpack and nitrous express thanks
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    if u do use ET streets use 26/11.5-16 that is the most common size the only reason to go to a 15 inch rim would be so u can mount a taller tire with a bigger side wall but u wont be spinnin et streets i could sleep on them they are soft.
      All things being equal the 15? wheel should be quicker. Wheel size can get funny but as long as you use the 2+1 formula your overall wheel/tire combo circumference should stay the same, whether it is a 15? or a 16? wheel. Say you have a 15? wheel with a low profile tire vs. a 16? wheel with a tall profile tire. Then you time SHOULD be different. I would also like to know the answer to this question: How does circumference effect your ¼ mile times? Another point is?.a 15x7 draglight will weigh less than a 16x7 draglight, figure in this is rotating mass, and your E.T. should be less with the 15? wheel. Also I would think that the circumference could make a difference in two ways, E.T, and Trap Speed. So I go back to the question I would like to have answered: How does the circumference of your wheel/tire combo affect your ¼ times?
      I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
        Thanks for the replys, slacker if the 26 16 et streets are good why are you getting the 15" rims later?
