Will this make the car run faster if I do it right, or would it just be pointless and make me look like a dumb sh**?
Shifting manually with an automatic
Manually shifting an automatic "right" means that you are shifting exactly where the computer has been programmed to shift. At best you gain nothing, and at worst you stand to lose a lot.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
<blockquote>quote:</font><hr>Originally posted by HAZ-Matt:
Manually shifting an automatic "right" means that you are shifting exactly where the computer has been programmed to shift. At best you gain nothing, and at worst you stand to lose a lot.<hr></blockquote>
Unless your automatic shifts before it should, in which case it would help.(i gaind .2xx manually shifting)New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
Manually shifting an auto is damaging to the transmission & rather pointless.
Regardless of when you shift it, you are still very much at the mercy of the computer.
If you are drag racing, leave it in drive or 3rd (3rd will help you slow down at the end some)
If you are autocrossing on a short track, you can
keep it in 2nd.
But you should not attempt to shift an auto manually.2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
I recomend not manual shifting for most..
However if your setup is very radical and your PCM wants to shift before it should, like on the 3-4 shift.. you may want to wind it out.
I wind out third gear and throw it in 4'th RIGHT after I cross the traps.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Thanks guys, I guess the solution to my car shifting a bit too low (5200 rpm) would be to just get a power programmer..-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
<blockquote>quote:</font><hr>Originally posted by 12secondv6:
I leave it in overdrive for n/a and nitroused runs<hr></blockquote>
Why? Would that help me any? What kind of effect on power does overdrive have? I thought it decreases power off the line, which I can see why that would help you to control all your torque.-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
so.... say since i did gears... and my tranny wants to shift a bit early, i could shift it manually and it would shift a little later where it is supposed to? until i get a reprogram that is
<blockquote>quote:</font><hr>Originally posted by Loochy88:
so.... say since i did gears... and my tranny wants to shift a bit early, i could shift it manually and it would shift a little later where it is supposed to? until i get a reprogram that is<hr></blockquote>
you COULD do that BUT I found that it won't IMMIDIATELY upshift when you shift up. It usually takes a few seconds and so you'll wind up hitting the fuel cutoff before the shift.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
