Mickey thompson et street front runners 26-4.5-15. Will these fit on a 15x3.5" weld pro star skinny rim?, or will i need the 15x5? What do you guys recommend? and what is the difference from a mickey thompson et street 26x10.5x15 and 26x11.5x15 will the 11.5 make me go slower than i would go with the 10.5? thanks
Are these the right front runners? please help
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
Dont get the the MT front runners just get a cheap set of kuhmo 165/15 from discout tire they are 50 a piece including mounting and balanceing. I currently have MT 26/11.5-16 i use them only for spraying the 100 shot out of the hole. If u can hook with a 26/10.5-15 or 16 the go with it cause the less tire that u can still hook with the better<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...2 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....6 days ago
