You could always try to remove the bumper supports? Need your A/C...if not delete it and get a 1LE A/C delete kit...if you have A/C though..sound deadening material in your car could be removed for some weight loss...put the battery in the back for better 60's...
Help me go from 15.19 to 15.0x with out new mods...
2003 Lightning 12.618@112.80<br />1996 Camaro Z28 11.751@115.96 MPH soon stupid fast!<br />1999 Mustang V6 15.36@90.92 MPH<br /><br /><a href=\"http://www.geocities.com/jmaxnakron/\" target=\"_blank\">1996 Camaro Z28</a> <a href=\"http://www.geocities.com/jmaxnakron/Melissa_V6_Mustang\" target=\"_blank\">1999 Mustang V6</a> <a href=\"http://www.geocities.com/jmaxnakron/Ford_svt_lightning\" target=\"_blank\">2003 Lightning</a>
<blockquote>quote:</font><hr>Originally posted by CANTONRACER:
You could always try to remove the bumper supports? Need your A/C...if not delete it and get a 1LE A/C delete kit...if you have A/C though..sound deadening material in your car could be removed for some weight loss...put the battery in the back for better 60's...<hr></blockquote>
I want the bumper supports...and I live in Texas...I would die w/o A/C. I have removed a good bit of sound deadening stuff, and moving the battery isnt cheap.<a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
<blockquote>quote:</font><hr>Originally posted by *K*night Rider:
Oh and you have an auto...I automatically beat you above 60 mph.
Anytime anyplace, just let me know when you want some!<hr></blockquote>
Let's go. Above ~93 you will have to use 4th gear... that is 1:1 ratio... same as my third, but the kicker is that I have 3.42 final drive whereas you have 3.23... I'll have a little more torque multiplication, besides the fact that I make a little more power.
And by the way, refering to you removing your limiter, this isn't a Honda forum... you can't say "We'll if I did this I would win." [img]smile.gif[/img]Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
<blockquote>quote:</font><hr>Originally posted by HAZ-Matt:
And by the way, refering to you removing your limiter, this isn't a Honda forum... you can't say "We'll if I did this I would win." [img]smile.gif[/img] <hr></blockquote>
yeah, but he'll be in a better part of his RPM range ;)2011 Camaro LS 6M, in black.
I don't how the 3.8 f-bods are, but I know that with my fiance's 99 3.8 Mustang it seems to run better with the recommended gas, which is 87 octane. It actaully has more pep and I got my best time out of it with that gas on snow tires, and the car is faster with normal tires.
Just a thought.2003 Lightning 12.618@112.80<br />1996 Camaro Z28 11.751@115.96 MPH soon stupid fast!<br />1999 Mustang V6 15.36@90.92 MPH<br /><br /><a href=\"http://www.geocities.com/jmaxnakron/\" target=\"_blank\">1996 Camaro Z28</a> <a href=\"http://www.geocities.com/jmaxnakron/Melissa_V6_Mustang\" target=\"_blank\">1999 Mustang V6</a> <a href=\"http://www.geocities.com/jmaxnakron/Ford_svt_lightning\" target=\"_blank\">2003 Lightning</a>
If you can't advance the timing then I'm not sure what the benefit would be to using a higher octane... been wondering that myself lately because I use 93 octane at the track, don't know if it helps/hurts.
As for battery relocation yeah it is kind of expensive, it didn't seem to help my launches either but I can't drive, hypothetically I don't see how it could not help. 40 pounds off the nose over the wheels.
I ran into cranking problems when I had my battery in the rear, and in fear of having to replace my starter I moved it back to the stock position, but kept the extra set of cables running from the back of the car so I can move it to the back when I want to go racing.
I wish I could cut a better 60 ft as well- my times only improved about 1 tenth going from 3.08/open differential to 3.42/lsd...
about a 15.6 @ 88 w/ a 2.3 60'ft to a 15.5 @ 88 w/ a 2.3 60' ft.
Bark
[ February 14, 2003: Message edited by: xjarayax ]</p>AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
<blockquote>quote:</font><hr>Originally posted by navyblue2000:
yeah, but he'll be in a better part of his RPM range ;) <hr></blockquote>
I dunno, I would be at higher RPM.
Adam, we will just have to remove your bumper supports. I suggest running premium at the track. We could start up your car and then take out the battery completely. Get a short belt that bypasses all the unecessary accessories. Get the flanges you talked about put on your exhaust, and take off the catback.
[ February 14, 2003: Message edited by: HAZ-Matt ]</p>Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
