Will 245 50 16 nittos be enough? - FirebirdV6.com/CamaroV6.com Message Board
  • Will 245 50 16 nittos be enough?
    i was gonna run 275 15 with prostars but cant really afford prostars , will the 245 16 nittos give me enough traction or will i spin? if i had prostars wouldnt they just reduce my et by like a tenth or two?
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    A .1 or .2, hope for the .1, it all depends on the weight saving and the tire you put on it.
    Also it is my understanding, and I am no mechanic, that the 275/245 is the profile of the tire not the width. The higher the # the lower the profile.
    The 60/50/40/30 is the width, the lower the number the wider the tire.
    Somebody clarify this if I am wrong.
    It would stand to reason that a DR, even in a 60 series, would hook better than a steel belt radial whatever they are called in a 40 series.
    Tire compound plays a bigger roll in traction than tire size, now all things equal the wider tire will get more traction then a narrower one.
    So I would think.
    I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
      You dont seem to have any suspension from your sig??? If this is the case get a PHR and LCA w/ nittos and you should be set. [img]graemlins/evilgrin.gif[/img]
      <b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
        Slow-N-ugly
        you gat it backwards. 245/275 ect... is the width in mm. 40, 50, ect.. is the profile stated as a percentage of the width. A 245/50 would be 245mm wide and the sidewall would be .5*245 tall.
        [ March 06, 2003: Message edited by: Charles ]</p>
        Charles<br />98 Silver Firebird M5<br />whisper lid, K&N, whisper cold-air<br />RKSport cat-back<br />BMR LCA\'s, STB, panhard rod, tunnel brace<br />B&M ripper<br />15.376@89.92 2.267 60\'
          I thought I may have had that backwards
            yes you do have it backwards 245 is the iwdth 45 and 50 is the profile height
              <blockquote>quote:</font><hr>Originally posted by Slow-N-ugly:
              So I would think.
              <hr></blockquote>
              I've always heard it the other way around.
              <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
                Alright, 245 is the width in mm. 50 is profile in mm also. With no power adder, but having higher than stock stall and powerpack, you will pushing the nittos pretty good. I'd also say go for some BMR Lower control arms and possible an aftermarket panhard rod. Those two items are the next on my list, now that I have nittos and a strong clutch, she wants to hop when I get rtaction.
                  Take a 245 50 16 sized tire.
                  The break down is as follows:
                  245 is 245 millimeters wide
                  50 is 50% of 245 mm wide or 122.5 millimeters high
                  16 is the size of the rim at 16 inches
                  Will they be enough???
                  Hmmm, well, I got to a 12.8 with them.
                  Dead hooking with a stock converter and dry 120 shot
                  Spinning with a pro yank 3200 and wet 100 shot.
                  Lower the psi to 20.
                  Heat them up more than bf drag radials.
                    yeah what james said
                    <b>Black 1996 Firebird</b><br /><b>Newest Edition: Harlan Window Switch</b><br />Nitrous Express Kit,ASCD big block hood, SLP Loudmouth, CATCO hi-flow cat, CAI, -Maf, LSD, Flameball Shifter<br /><b>Best N/A 1/4 in</b> 15.216 @ 89.82 <b>Best N2O 1/4 in</b> 14.352 @ 97.46 &lt;--w/clutch slippage<br /><a href=\"http://www.geocities.com/motorhead69/\" target=\"_blank\">My homepage</a><br /><b>AIM:</b>MotorHead75068 <b>YIM:</b>MotorHead69
                      I can't hook for **** with them [img]smile.gif[/img]
                        <blockquote>quote:</font><hr>Originally posted by Tiago NOS'd Bird:
                        I can't hook for **** with them [img]smile.gif[/img] <hr></blockquote>
                        You could have no tires on your car, and your wheels welded to the a metal floor of a VHT factory and not hook :D
                        seems like they shoudl help but as said before go with suspension, you will be surprised I get my good 60's on the cheapest tire they mad in 235 or 245.
                        [ March 07, 2003: Message edited by: MustangEater8251 ]</p>
                          <blockquote>quote:</font><hr>Originally posted by MustangEater8251:
                          seems like they shoudl help but as said before go with suspension, you will be surprised I get my good 60's on the cheapest tire they mad in 235 or 245.<hr></blockquote>
                          Now, that's the truth. 2.04 60' w/ 2.03 best on the stock Goodyear GAs. LCAs helps ALOT. [img]graemlins/thumbsup.gif[/img]
