to those with the SSM package. - FirebirdV6.com/CamaroV6.com Message Board
  • to those with the SSM package.
    what increase did you notice in your quarter mile time?
    also, if you may, could you provide if you got the full package, and if so, what spec cam
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    I went from a 14.0 NA with 3.73 to a 13.6 NA with 4.10 gear..
    heads/cam 212/212 112LS 108IC
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      <blockquote>quote:</font><hr>Originally posted by Magnus:
      <hr></blockquote>
      So not that much because the gears are what basically helped you out ?
        I'd say gears were worth .1...
        but the faster you go, the harder it is to gain.. So I figure from a 13.9 NA to a 13.6 NA is a pretty damn good improvement.
          <hr></blockquote>
          You aint shi**ing. I would love to run that. I am hoping that I will run 13's with 85 dry/headers/intake/2.5 catback/P&P SSM heads
            <blockquote>quote:</font><hr> You aint shi**ing. I would love to run that. I am hoping that I will run 13's with 85 dry/headers/intake/2.5 catback/P&P SSM heads
            <hr></blockquote>
            you definately should, especially w/the nitrous...
              <blockquote>quote:</font><hr>Originally posted by WickEdSix9838:
              <hr></blockquote>
              how about without the nitrous and instead of the nitrous a cam?
              intake/2.5cat/P&Pheads/cam/headers?
                but how about from a totally stock engine.
                5speed.
                going from stock. running normal 1/4 mile times at sea level.
                to SSM package, full exhaust and cold air intake. LSD with 3.42 gears.
                should i pick up at least a little over a second in the quarter mile?
                im saving up for all these mods at once
                  i went from a 14.8 to 14.45 when i got my power pack. i got the whole shebang. even the crower regrind.
                    WTF 1900$ and all you gained was .4 seconds? WTF Have you reprogramed(flashed) the pcm?
                      a COMP cam will help out a bit more than a crower regrind.
                      A good heads/cam setup will be worth ~ .5 and 5mph. With 2 less cylinders than a V8, the gains aren't as large as you see with the LS1's. :(
                        <hr></blockquote>
                        You will let us know how great the gains are with the cam/head combo on the LS1 right [img]tongue.gif[/img]
                          Cam, yes.. heads... no.. not unless I begin to spend money like its water again.
                          I will have a cam only car that makes over 400rwhp though and hopefully runs 10's NA. ;)
                            wow. so only a cam huh are you planning anything else for it say maybe juice or forced induction in the future?
                              NA only.. I am an NA king. I think it takes much more skill and precision to make an NA car go fast. [img]smile.gif[/img]
