do you start out in d or od when drag racing? and if you start out in d do you shift into od before the 1/4 is up? if so how far down the track do you wait to shift into od?
Calling all the 14.5 and faster n/a 3.8 people please reply
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
I just figured some of the people with 3.73 and 4.10s would have to shift into od with all the other mods but wasnt sureLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
M5 here and I'm having issues hitting the rev limiter in 3rd b/f the 1/4 with 3.23's. The best I've trapped is 97.02, and suppositely the rev limiter in 3rd is like 99-101.
Actually assuming 1.46 3rd gear, 3.23's, and 245/50-16 tire 97 is where the limiter is. With a 235/55-16 tire you can make 99 b/f you bounce.
[ April 08, 2003: Message edited by: Seppo Kaitainen ]</p>Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
http://seppo.hopto.org/
I trapped 98mph with 4.10 gears and 26" tires in 3rd gear.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
So far i have never had to shift into 4th gear at the track<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
i start in 1st gear. [img]smile.gif[/img]
also i have never hit 5th (the same gear as 4th on an auto) I am in 4th at the end of the track, which is 1:1 just like an auto's 3rd gear. I trap at 98.86 and i still have room to go before i would have to go into 5th (od). Also the hypertech helps me rev higher in each gear therefore letting my 4th go higher than most, but i still dont get past 5500 rpm's with the 410's in 4th. So youd have to be MOVING to worry about hitting OD. I still have 1k+ rpm's left before i run outta gear.
[ April 09, 2003: Message edited by: camaro_zach ]</p>
<blockquote>quote:</font><hr>Originally posted by Seppo Kaitainen:
[ April 08, 2003: Message edited by: Seppo Kaitainen ]<hr></blockquote>
Is 3rd 1.46? Someone gave me the impression that it was in fact 1.34:1. If that is the case, you get a 105mph at 6000rpm in 3rd w/ 3.23's. But if it is 1.46, the your numbers are right [img]smile.gif[/img]Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
<blockquote>quote:</font><hr>Originally posted by camaro_zach:
also i have never hit 5th (the same gear as 4th on an auto) I am in 4th at the end of the track, which is 1:1 just like an auto's 3rd gear. I trap at 98.86 and i still have room to go before i would have to go into 5th (od). Also the hypertech helps me rev higher in each gear therefore letting my 4th go higher than most, but i still dont get past 5500 rpm's with the 410's in 4th. So youd have to be MOVING to worry about hitting OD. I still have 1k+ rpm's left before i run outta gear.<hr></blockquote>
I'm getting that on 235/55R-16's, 4th gear in a 4.10 equiped M5 would be good till almost 114mph, and almost 112 if you ran 245/50's.Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
i just picked up my car from the mechanic yesterday and we go out on the road. he tells me to drive it around and check it out. we stop and he tells me to do what i would usually do at the track. so i ask him should i flash the converter? he says do what you usually do. so i flash to 2500 and let her rip in drive. [i am not too impressed] he tells me as we slow down that HE would have put it in 1st and launched from there. i told him when i first started drag racing i asked about that and the consensus was that if i wanted to shift i shoulda got a manual.6s.......under the hood or under the belt, they just dont cut it.
The thing is your car revs real high at wot with an auto, so I mean you might as well let it do the work for you. I leave it in 3 and let it rip.
<blockquote>quote:</font><hr>Originally posted by Jason Morgan:
you can hold 3rd gear to 118 stock you shouldnt be close to that unless you have alot higher gear (4.10 with out a reprogamed pcm) and are on spray<hr></blockquote>
Thats what most these autos will do, the LT1s aren't but a couple miles more than that before it shifts to fourth.So if your loud mouths shaking and your consoles vibrating<br />bald 17 inch ZR1s got you Trans Am skating
<blockquote>quote:</font><hr>Originally posted by hawgs:
i dont think anyone is trapping high enough to go into overdrive...<hr></blockquote>
Hawgs said it. Don't worry about overdrive. No one that is normally aspirated will come close to need shifting into overdrive at the track. Even with 4.10's.
And yes third gear is 1.34:1<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
