Need to break into the 14s - FirebirdV6.com/CamaroV6.com Message Board
  • Need to break into the 14s
    I have a 1996 AOD camaro and am running 15.4 right now with a catback and slp intake, I want to make it into the 14s N/A.... Where do I start and whats the best way..< after I hit 14.9 Im plaining on running nitrous>
    Thanks
    Nick
    if you do not have 3.42 gears and a limited slip, that should be your next mod. if you do, then a stall converter is great for an auto. aluminum drive shaft, high flow cat, lca's, low temp thermo, any weight reduction you can do, fan switch for consistency, and better tires.
    also, dont forget to run on a 1/4 tank, (any lower and i would think your engine could miss under hard accel) and increase your front tire pressure to about 40 psi when running.
    Visit My F-Body Page
      get limited slip with 3.73 and a 3000 stall torque converter and you'll be in 14 land all day long.
        <blockquote>quote:</font><hr>Originally posted by 96V6:
        I have a 1996 AOD camaro and am running 15.4 right now with a catback and slp intake, I want to make it into the 14s N/A.... Where do I start and whats the best way..&lt; after I hit 14.9 Im plaining on running nitrous&gt;
        Thanks
        Nick
        <hr></blockquote>
        Did you used to own a Mustang or something? Here in the f-body world it's not called an AOD, it's an A4 [img]tongue.gif[/img] :D
        ---<br />-\'95 3.4L M5 Camaro
          No. no mustang here... Just a ford fan.. oops..
            little embarrasing but, what are either of those terms? "aod" and "a4" im very tired...time for bed
              <blockquote>quote:</font><hr>Originally posted by Chevy Lovah:
              little embarrasing but, what are either of those terms? "aod" and "a4" im very tired...time for bed<hr></blockquote>
              A4 - Automatic 4-speed
              AOD is Ford's transmission. It's usually called AODE but I'm not sure on it's abbrevation. Automatic OverDrive? and the one with the E I'm guessing means electronic.
                well then, i'm not an A4! thanks
