Dissapointed - FirebirdV6.com/CamaroV6.com Message Board
Dissapointed
  • Dissapointed
    After all the mods i did to my car i only ran a 16.6 :( . i was almost sure i would run something at least in the 15's. do you guys think with the stuff i have done that i should be in the 15's, if so what could be wrong?
    1995 black firebird,t-tops,3.4L M5 Comp cam,gutted cat,Cold Air,80 series flowmaster,limited slip rear end with 3.42 gear, Hurst Billet Plus, 17\" American Racin Torq Thrust II
    Man, don't get disappointed! I ran a flat 16 the other day, And I have a 3.8 with 3.42's and lsd and minor mods! Of course my pcm isn't programmed, but I had bad traction and stuff. Try again some other time, did you post your whole times list? Maybe you just aren't getting a good enough of a launch?
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
      No, i was getting good launches. i had minimal spin. my local track just got resurfaced, so its pretty nice now.
        What is a decent 60' time?
          anywhere from 2.3/2.2's on down. what were you getting?
            my 60' time was a 2.382
              You shifting good [img]tongue.gif[/img] ? i definately think you should be faster than that.
              New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
                <blockquote>quote:</font><hr>Originally posted by Fear_Factor:
                my 60' time was a 2.382<hr></blockquote>
                that's 1 of your problems. @ least, get it down below 2.30. another is your 17" rims.
                  I really don't think its that bad considering what you have.
                    those 17s are hurting your times
                    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                      Well, we need more info
                      Track conditions (weather etc)
                      What did you do at the track for preparing? (sit there w/ the car idling, tire psi and so on)
                      First time out w/ this car (experience)?
                      MPH?
                      1995 black firebird 3.4L M5
                      Comp cam &lt;--- what kind?
                      gutted cat &lt;--- gutted stock?
                      homade ram air &lt;--- I tried this, slp is better
                      how is your home made kit done?
                      80 series flowmaster &lt;--- muffler or cat back?
                      K&N filter &lt;--- drop in? conical?
                      limited slip rear end with 3.42 gear &lt;--- ok
                      Hurst Billet Plus &lt;--- does nothing
                      17" American Racin Torq Thrust II &lt;--- are they heavy?
                      Bridgestone Potenza 730 245/45/zr17
                      going to track soon to get times [img]smile.gif[/img] &lt;--- my guess is not much track experience huh?
                      I'm just trying to get feedback
                        the air prob isnt just great in missouri...
                          YOur 60's can be improved
                          I hit 2.0 flats, I have a 5-speed, and 3.42s with LSD.
                          I also have a 1le tranny mount and a 21mm rear sway, those might help my 60's over what you have. I also have a poly torque arm bushing but it didn't really do wonders for my 60's
                          You shoudl be able to get it down to at least 2.1, they say .2 in the 1/4 for every .1 in the 60'
                          Can you post your entire run, I would really like to compare it against some of my runs since you have a 3.4L, 5-speed and 3.42s.
                            Comp cam :206/212
                            gutted cat : i gutted it
                            ram air or cold air is a dryer vent from aor box to infront of air damn (took out extra plastic ****)
                            80 series flowmaster : muffler
                            K&N filter : drop in
                            My run was:
                            60' 2.3282
                            330 6.880
                            1/8 10.651
                            Mph 65.06
                            1000 13.891
                            1/4 16.635
                            Mph 81.72
                            It was about sunset and a little cool. i think i launched about 2700 rpm's. i have been to the track before and im pretty good on a stick. i was speed shifting when i ran and i shift about 5500. although do u guys think i should have to hit 4th or continue to run 3rd out? i hit 4th on this run. and also how bad do u think the 17's hurt my time?
                              in the lanes i put my hood up and tried to keep it off. my psi was about 22 lbs. and i have been driving my car for almost a year. although my car was a recoverd theft, so i dont know what kind of condition the clutch is in, but it doesnt seem to slip any.
