Wideband Dyno?? - FirebirdV6.com/CamaroV6.com Message Board
Wideband Dyno??
  • Wideband Dyno??
    Exactly how is the air/flow ratio measured on a wideband?? Experiences with this?? Getting tuned on a dyno within a week or two...
    2004 CE Corvette 10.86@132mph
    2011 Cadillac CTS-V
    2006 Mitsubishi Eclipse GS
    they use a different o2 sensor that is put into your exhaust pipe. It's a very accurate sensor, more acurate than the normal ones in your car.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      SO... if i wanted to put an A/F ratio guage in my car.. im better off buying 1 wideband o2 sensor, and adding it to my y-pipe or something?
      96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
        wideband monitoring kits are around 400 bucks
          not a problem... just gives me a reason to save more money and spend less on taco bell
            Can't you buy a widebad O2 sensor and then just hook it to a normal A/F Gauge. I heard that works well. Not quite as expensive.
            1997 Dodge Viper GTS
              no.
                As you said, Keith, it's suppose to be more accurate. I've noticed with autotap, the numbers fluctuate too much and it's difficult to get accurate readings. I have to keep freezing each frame during a run to read the millivolts. I was told that autotap's not as accurate because the readings are going through the PCM first. I guess wideband is the way to go afterall.
                [ September 19, 2003: Message edited by: Shirl ]</p>
                2011 Cadillac CTS-V
                  <blockquote>quote:</font><hr>Originally posted by Shirl:
                  <hr></blockquote>
                  Shirl With dynoing on a widebad I was able to tune my A/F so it was 13.0 across the board while the car is being pulled on the dyno.....If you have tuning capabilities do it.
                  Eric
                  2005 Mustang 4.0
                  1996 Camaro Conv
                  2000 Ford Excursion
                  "Darkness Falls"
                    autotap's readings aer as accurate as the sensors will alow, the PCM doesn't modify them at all.
                    At WOT your #'s should remain fairly constant. If you have a lot of fluxuation over +/- .2 then I'd look at fueling. It should be very steady and changes should be gradual.
                    One thing I bet your car does is lean out a little bit in third.
                      <blockquote>quote:</font><hr>Originally posted by Magnus:
                      <hr></blockquote>
                      As most of our cars would especially if there are Intake or fuel changes done. Thats were the wideband come into play...With me I use the MAFT and as I am going up in the RPM band on the dyno I just click more or less fuel...By the time I am done tuning I run 13.0 across the board....
                      Another benifit is when you have the wideband done and know where your tuning is you will alway know your base and WOT so that you can adjust for things like a cutout at the track where you might need to run another 2% richer at WOT....one click and when done at the end of the night just click the WOT back to where you started.
                      Eric
                      2005 Mustang 4.0
                      1996 Camaro Conv
                      2000 Ford Excursion
                      "Darkness Falls"
                        if you richen it up using MAF T+ for a nice fuel mix in 3'rd, you'll be even richer in 1'st and 2'nd.
                          so then how do they fix the leanness in just 3rd gear???
                          also. im gonna be getting a wideband o2 kit for my bday... would i have to get 2 sensors.. one for each bank? or can i just put one wideband o2 sensor on my y pipe where the two banks meet?
                          [ September 20, 2003: Message edited by: Tyler ]</p>
                            PCM reprogramming
                              PCM reprogramming<hr></blockquote>
                              Untrue....
                              if after tuning with the MAFT dynoing the the car with the wide band...if its 13.0 across the board it is what it is...it isnt richer because of gearing or shifting. Dyno sheet is on my website to prove the point.......
                              Eric
                              2005 Mustang 4.0
                              1996 Camaro Conv
                              2000 Ford Excursion
                              "Darkness Falls"
