Anyone here done this? The hold-down on the front of my battery is broken, so on a hard launch the battery flips back and the positive terminal grounds on the A/C accumulator. The only way to replace the hold-down is to replace the coolant reservoir as well (about $35 from dealer). I could use the weight off the nose, but is it worth the trouble to put the battery in the back? What else do I need to do to make it NHRA legal? I heard once that if the battery is relocated then there has to be a cutoff switch on the back of the car?? Any opinions/advice?
Battery relocation
To be NHRA legal, you need to have it in a approved containter that is secured by some form of a hold down. And yes, you do need to have a external rear mounted cutoff switch. By the time you run all the wiring, the weight savings are negligible.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
I tried it with the generic Summit relocation kit. Couldn't get it to work well. It would crank over about 10 times or so before it would start. I didn't like that much. A lot of headache, eventually moved it back to the front.
Was using an Optima Redtop, too.
I think the problem was not having a good enough ground in the back, our cars are not unibody, and therefore that causes a grounding problem.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
I have moved my battery to the trunk and it is definetly a weight advantage your talking about moving 35lbs or more to the rear which creates at least a 70lbs weight shift. There are switches that use a T handle that you could make come through the floor to handle the cutoff switch. Tha starter is where I ran my + line to and that did away with the clicking problem I had. What happens, is if you dont ground the cable or use a large enough gage you will lose amps to the front of the car, to avoid this you can easliy mount a ford battery solenoid up front as a main + connection for your car which will help with the cranking problem or you can try what I did. #1 thing to get is a bigger cranking amp battery.Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91
the rules about an approved container are dependant upon where you put the battery. on thirdgens we tend to use the spare tire well, this does not require a box because the body panels are considered a "firewall". the safety switch is a definate must.
one of the biggest mistakes peopel make when they relo is using crappy wire. you need to find 1gauge cable, most kits coem with 1 or 2 gauge "welders cable" which is harder to work and has a greater resistance. good wire is pricey, but totally worth it. you can get it at any good stereo shop.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
<blockquote>quote:</font><hr>Originally posted by xjarayax:
I think the problem was not having a good enough ground in the back, our cars are not unibody, and therefore that causes a grounding problem.<hr></blockquote>
Me too, I tried summit's kit + flaming river battery cut off switch.
Weight transfer ROCKED!!!
Starting sucked :(Race car - gone but not forgotten - 1997 firebird V6
Cracked lip?
Cheap fix, is wedge a roll of electrical tape, between the frame behind the headlight, and the battery, then put a generic 2 pin battery hod down form advanced auto for liek $3, and jsut force it under the lip of the battery tray.
Works great! Past tech with it a many times autocrossing, and that is the thing they check the hardest. [img]smile.gif[/img]
James, I assume you aren't using it anymore?? Do you still have the cutoff switch? (would you be interrested in selling it?) Where did you put the switch?-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Let's bring this back up-- I'd really love to get my battery in the back again if we can find a sure way to make it reliable starting.
I think my ground cable was 2 ga?AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
Screw relocation -- I have a 10.8 lb or so Harken Genesis battery. Cost me actually $24 shipped or so from e-bay (yes, 24), and dropped maybe 20 lbs or so. Never had a starting / cranking problem.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
