Just use a spacer... SO much easier.
Finally did it! 11.888 @ 113.57 all motor!! [LS1]
<blockquote>quote:</font><hr>Originally posted by hawgs:
Just use a spacer... SO much easier.<hr></blockquote>
Cool thanks..Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
I just used a 5/16" spacer on the front. On the back I had to grind. I definately wouldn't grind the fronts. The front calipers recieve ALOT of stress when you brake, especially after a 1/4 mile pass. Grinding it WILL weaken the caliper. I've even known a guy that had the back calipers to break (twice!) after grinding ... of course he was trapping at 132mph. :eek:
If you must grind: I did my rear calipers by first spraypainting the caliper, then putting the wheel on and turning it. Then take the wheel off and see where it scraped the paint off. Continue until the wheel no longer scrapes away ANY paint, then go over all of it once more for good measure.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
where did you get your intake? i didn't know they made other intakes for our 3.8s96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
ooooohhhhhh. i was like What the???? oops.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Sorry about that guys.. even though this is a pretty old post, I put LS1 in the thread title to avoid anymore confusion...
BTW: looking to beat that time next sat with 27" mickey's on 15" rims, a shortbelt, and a little bit of weight reduction. [img]graemlins/burnout.gif[/img]-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
I wonder what my car will run with these mods? Stock I ran 13.4's (very hot out)
TSP clear lid - Pacesetter LT's - ORY - TSP 232/228 .595/.588 112 LSA Cam- Patriot Stage 2 5.3L heads - Katech oil pump - manley pushrods - comp 978's - !AIR - !EGR - K&N
With some DR's and a new rear I am hoping low low 11's. With the stock rear, DS, and clutch, maybe 11.5's?
Biffy<b>1999 Camaro SS Black.</b><br />408ci motor on order<br />300HP DP N2O<br /><br />H/C, and lots of other toys.
<blockquote>quote:</font><hr>Originally posted by Biffy:
Biffy<hr></blockquote>
If you can make it to the track without hitting any curbs...
Biffy...out of curiosity..what # is your SS? And what color is it?
Hint: Check out other V8 message boards and look at someones sig. Copy and paste their info here. You want to make sure they don't post too much though, otherwise it will be obvious you took their info. Now go!94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
<blockquote>quote:</font><hr>Originally posted by Camaro_SLP:
Hint: Check out other V8 message boards and look at someones sig. Copy and paste their info here. You want to make sure they don't post too much though, otherwise it will be obvious you took their info. Now go!<hr></blockquote>
Black 99 SS - #4130
BTW, those mods are mine...I can prove it if you really doubt it...<b>1999 Camaro SS Black.</b><br />408ci motor on order<br />300HP DP N2O<br /><br />H/C, and lots of other toys.
