I bracket raced at the first points race sat. they changed the lights to LED I can't get ajusted to them. I usually take of on the last yellow and get .5XX RTs but now I get red light when I do. I tried taking off a little later but got .7XX any suggestions? I ran PRO and SPORTSMAN I red lighted 1st round PRO and bought back in and red lighted 2nd round PRO. got lucky in sportsman and made it to 6th place in points but ended up red lighting in that too. I am going back sat. I will be running the entire season for points gotta get it right. :mad: they ran reg. lights all in feb then change the first points race day :mad:
raced bracket at the track sat. they have new L.E.D. lights
2000 convertable Camaro White <br />3.42 LSD<br />9.45 1/8<br />8.72 1/8 NOS<br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/Suspension/driveshaft_loop/driveshaft_loop.html\" target=\"_blank\">Driveshaft Safety Loop Guide + prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/braking.html\" target=\"_blank\">Line Lock Guide + Prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/rearend/rearendcoversupport.html\" target=\"_blank\">Rear End support/girdle/cover Guide + Prices</a>Tags: None
just gonna have to re-adjust...the LED's come on way quicker than the original bulbs...just try to wait a tiny bit longer before you leave....not easy but if its what u gotta do then do it...try and go run a TNT to try and get used to them, that way you can get a lot of passes
BTW...your car is photoshopped as hell in ur pic....<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
guess its just gonna take a little more pratice at least everyone has to adjust being they just changed it. wickedsix9838 checkout this pic
http://www.one8thmile.com/firebird2000 convertable Camaro White <br />3.42 LSD<br />9.45 1/8<br />8.72 1/8 NOS<br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/Suspension/driveshaft_loop/driveshaft_loop.html\" target=\"_blank\">Driveshaft Safety Loop Guide + prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/braking.html\" target=\"_blank\">Line Lock Guide + Prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/rearend/rearendcoversupport.html\" target=\"_blank\">Rear End support/girdle/cover Guide + Prices</a>
Try staging a little shallower than you normally do. This will give you slightly more "roll" through the beams and kill some reaction time. Leave the same time on the tree and adjust how much you bump in when you stage.
RonI know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
I stage as shollow as possible always. I went back to the track sat 3/13/2004. got much better at the light I adjusted my rollout. nomally I powerbrake to 2500rpms this time tried new idea and it worked
first run no powerbrake foot one inch off pedal
rt .777
second run just touching the pedal
rt .654
third run powerbrake 1200 rpm [img]smile.gif[/img]
rt .517
forth run powerbrake 1100 rpm
rt .570
fifth, sixth, and seventh 1200 rpm [img]smile.gif[/img]
rt .514 [img]smile.gif[/img]
rt .547 [img]smile.gif[/img]
rt .522 [img]smile.gif[/img]
rt .505 this is the round I lost on I dialed in at a 9.930 and ran a 9.923 so close :mad: I knew I had the win if I let out of it I had a .100 lead and didn't let out because I was tring to get an Idea for my next dial.2000 convertable Camaro White <br />3.42 LSD<br />9.45 1/8<br />8.72 1/8 NOS<br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/Suspension/driveshaft_loop/driveshaft_loop.html\" target=\"_blank\">Driveshaft Safety Loop Guide + prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/braking.html\" target=\"_blank\">Line Lock Guide + Prices</a><br /><br /><a href=\"http://www.one4thmile.com/camaro-firebird/93-02/98-02/rearend/rearendcoversupport.html\" target=\"_blank\">Rear End support/girdle/cover Guide + Prices</a>
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
