How Much Loss from Leaving the Heater on?? - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    I always run my heater while I am in the staging lanes then turn it off before I run.
    I turn it off because with the windows up and the heater on in the summer obviously it would get quite uncomfortable in the car.
    Turning your heater on should cool the coolant down a little more since it is drawing heat out of it.
    SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
    • #32
      Having a heater on won't slow the car at all.
      It was probably just a bad run for him.
      The trick that some use is to keep the heater blowing full blast in the staging lanes moving up to keep the car from heating up as quickly since it's not getting a lot of air to cool it.
      I've tried it and not seen any noticible increase/decrease in time.
      Chris
      <b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
      • #33
        Originally posted by brandonppr:
        I think it would make a maybe close to a .5 second difference if you remove the belt which would cause no alt. drag at all + no Power steering or water pump. so how could turning the heat on cause as much loss as all these things?
        nope it won't....
        he is a post I had to show some local guys that my times were not B.S. and claimed removing the belt will not have any effect.
        knife13 wrote:
        so if i take off my belt and disconnect my exhaust i run 14's, damn how come everyone isnt doing it. *notice the sarcasm
        Ill still have to see it to believe it, Ill have to run him sometime then.
        I don't know, worked for me...
        how come I ran a 15.4 in my old 3.4L v6 beating guys with heads and cams in the same motor.
        You don't get fast times by just throwing money at your car...
        did you know if you just went to the track and practice I bet you $50 you could run a high 14... you have a freaking 2.6 60' you do know that every 1/10th in the 60' is about 2/10ths in the 1/4 right?
        Cut your 60' to a 2.2(still not good but reasonable) and you might run a 14.8-14.9 probably at least a 15.0. Probably only cost you ~$60 for 4 trips to the track.
        I cut 2.1s with an open diff on bald tires at OSW(and we know how they are known for great traction)
        Want some history... my dad bought the car summer of 2000
        My clutch went out on my 94, on my way to ft. lauderdale visiting my parents, my dad let me take his camaro up while my car got fixed since I had class the next day.
        So I took it to the track that weekend and on OCT 28, 2000 I ran these times when the car had 7,000 miles on it
        16.288@87.95 mph with a 2.502 60'
        15.875@88.25 mph with a 2.347 60'
        16.014@87.06 mph with a 2.499 60'
        I couldn't launch worth a crap cuz the power band in the 3.8L was completely different between my 3.4L and the 3.8L, shift points and were waaaay off and best launching was different.
        over 3 years later with alot more practice on the T5, I buy the car from my dad.
        Nov 19 2003
        ran bone stock to the original paper filter no track or any other type of mod. Didn't even play with the 32 psi on all 4 corners
        15.466@90.24 with a 2.344 60'
        15.402@289.58 mph 2.249 60'
        15.355@90.25 mph 2.196 60'
        15.581@89.38 mph 2.393 60'
        Dec 17 2003
        -messed with tire pressure, open TB and descreened MAF
        14.930@91.92 with a 2.135 60'
        15.196@91.05 with a 2.213 60'
        15.051@91.63 with a 2.172 60'
        15.619@90.01 with a 2.410 60'
        Dec 19 2003
        -(2 days later) Full exhaust, descreened maf, open TB, pulled belt
        14.866@93.40 with 2.170 60'
        15.137@92.23(belt left on for this run, car wasn't cool enough car was hotlapped only 23 min. between runs)
        14.822@93.41 mph 2.229 60'
        14.629@93.34 mph 2.159 60'
        Track closes...
        Jan 14 2004
        -Exhaust unhooked, open TB, descreened maf
        14.914@92.60 mph 2.181 60' (ran with belt on)
        15.010@92.98 mph 2.291 60' (Belt on again)
        14.752@94.35 mph 2.211 60'(belt off) notice I jumped ~1.5 mph in less then an hour?
        14.582@94.88 mph 2.169 60'
        Jan 16 2004 (2days later)
        14.856@93.31 mph 2.145 60'(belt on people hounding me for ties with belt on)
        14.889@93.36 mph 2.215 60'(same as first run)
        then I ran a
        60' 2.117
        330 6.027
        1/8 9.299
        mph 75.37
        1000 12.103
        1/4 14.467
        mph 95.45
        then
        14.506@95.26 mph 2.107 60'
        14.884@94.79 mph 2.297 60'(jsut antsy with my times a f'ed the launch)
        January 21st 2004Next wednesday
        Ran high 14s with a best of a
        14.687@93.46 mph 2.105 60'
        February 18th 2004
        had my Zr1s ons
        I had clutch problems all night long, I was running 9.8-9.9 1/8th miles and 2.2 60's
        April 8th 2004
        New plugs, wires, fuel filter and CAT
        Clutch problems again... It wasn't as bad this time, I was riding the clutch getting up to the line hard to get some heat in it.
        had all bad 1/8th miles, my best run was a 14.805@93.47 mph, with a 2.198 60'(clutch slips at line when I have it fully released)
        those are the timeslips I have on hand, I have run it more but I cannot find the slips, I lost a few, threw a few out.
        Reason why I posted all this crap most of you don't car about is I don't like being called a liar and have people think I am a stupid ricer. Not sure when I will be able to make it out, so I put these up.
        enjoy...
        • #34
          I thought this thread died... Who dug it up?..... [img]graemlins/rofl.gif[/img]
          • #35
            on our cars (GM) when you have the heater on in defrost, or the last 2 settings all the way clockwise on the knob, it runs the AC...
            btw, the alternator puts the same drag on the belt at all times... when more current gets pulled, it just falls short, it doesn't increase the RPM's or workload like the AC does.
            and yes, running the heater is like using a small secondary radiator, it helps cool the coolant down.
            I don't see how any of this would effect the time unless you had the heat on in "defrost" mode which would run the AC, robbing some HP.
            \'94 Firebird, 3.4 M5.<br />Arctic white w/ red anniversary stripe. ASP underdrive pulley set, Magnaflow 2.5\" stainless catback, CAT, Pacesetters, K&N FIPK2, 1000 watt stereo system capped 1F, Eagle Alloys 16\" 077\'s, 180 Deg. Thermo.
            • #36
              Yeah, we were talking about this yesterday and the heat along with the defroster were on during that run. So, you're theory sounds correct...
              [ April 16, 2004, 11:19 PM: Message edited by: Shirl ]
              2004 CE Corvette 10.86@132mph
              2011 Cadillac CTS-V
              2006 Mitsubishi Eclipse GS
