traction at track and road way different...why? - FirebirdV6.com/CamaroV6.com Message Board
  • traction at track and road way different...why?
    when i am on the highway i cannot break my tires loose, but at the track I had a hard time getting traction. I tried no burnouts, then burnouts without water( made things worse), then burnouts in the box(still chirped hard at the line) on my "new best" run I even caught second gear rubber. then on the way back up the trap I would keep it in first and break them loose at 25 and sometimes 30. then I pull on the real road and i cant even seem to get a chirp.
    whats up with this?
    does an auto with 3,08s usually not burnout easy or ? you dont think my converter is going do you? my tires are 225/60/r16V and grip like no other on the road, but at the track they seem like they are 2 inches wide.
    96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
    I had the same problem last night at my track. My first run, 9th that night, I hooked good and got a 2.33 60'. But after that I ran slower and slower and slower. I was chirping my tires real bad and I even did a small burnout in the bleach box. I lowered my rear tire pressure to about 25.5 but still couldn't grab. I am thinking the track prep sucked and there was a small amount of water at the line. Everyone last night after about the 200th run had a hard time hooking. I did get a new best of 15.7128 @ 87.21
    New Toy Red 94 Formula LT1
    RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
    crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
    The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
      Get line locks and breaking your tires loose will never be a problem.. ;)
        on the street you generally your tires are well heated up...
        When your car is cool... get in it pull onot the the street and do a drag launch...
