The only thing I had done was a PCM flash after the gear swap. I am going to get the custom tune from TSP in the next week or 2.
My 60' sucks. please analyze my slip
Raise that tire PSI, if you're not spinning then the low pressure could be making you bog the '60 and it will affect your top end.
Try flashing the converter (stomping it from idle) there's really very little point in stalling your converter if you're not having traction problems.
You don't need to do a burnout on street tires, avoid the water box as much as you can. If you run through some water, spin the tires just enough to get the water and junk off.-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
Originally posted by '98 BlackBird:
I just turned 100,000 miles that Friday and no I have not changed anything as far as spark plugs, coil packs, or wires. I does not seem to be bogging at the line and it definately is not sputtering.
I am thinking it may be something internaly with the engine. Would a transmission fluid change help or a readiator flush?
is ur engine hot before you run?~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
LCA's
is ur engine hot before you run?New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
Today was my first time at Track:
Here is my time with my girlgriend in the car with me:
60' : 2.413
1/8 10.188
1/4 : 15.788
RT : .626
78F
I've a manual...
I can't understand: I can't avoid to spin my tires on the track... on the street they doesn't spin like this...
I have to work my launches...99\' Camaro M5 3.23 LSD<br />-SLP CAI,K&N,Whisper Lid,!MAF Screen<br />-2\'5 Flowmaster Catback <br />-BMR STB<br />-Kumho 712 supra 245/50/16<br /> <a href=\"http://www.camaroV6.fr\" target=\"_blank\">http://www.camaroV6.fr</a>
I believe the stock stall is about 1800 in our cars. I had the best luck stalling to about 1800- 2000 and nailing it on the 3rd yellow, I got a 2.17 60ft doing that with an open diff. I just sent my PCM to TSP and am expecting much better 60ft's now with the verter and Tq mgmnt minimized... ;) BTW I've cut consistant 2.0x 60fts since the verter install but Tq mgmnt has been eating me alive so we'll see what I can do once I get the reprogrammed PCM in there.. :D2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
My 60' is right on track with yours and I have 3.73s..I did get a 2.349 once though when I hit my 15.69. I did the same thing as you(HP tuners) and I hope that fixes it. I think traction control is stopping my 60'because my tires will not spin from a stop but make about 1 rotaion when I hit second(in an auto). Please tell me if the PCM helps.thanks97 RS,3.73 LSD,Flowmaster,Shift Kit,Edge TC,HP Tuners,EWP,SLP CAI,160*,Touchscreen monitor,& Alpine Stereo(155.2dB)15.27 N/A 1.9X 60\'s and a magic switch.
Hopefully I will find out this Friday at the track if the PCM tune helped.
My best 60' is 2.30 and that was on street tires with 3.08 gears, my 3rd run ever at a track LOL.
my 60' average is 2.414.New Toy Red 94 Formula LT1
