Where are you planning on putting the cut-off switch? A tasteful install of the switch is the only thing that's kept me from doing this already.
-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
I had a little problem with my stock battery when I relocated, but when I swapped in the optima, it worked out great, no more problems. Im running the TAYLOR battery relocation kit. This was on the TA too...
Yes- a cutoff switch must be located on the rear of the car and clearly labeled. The switch must not only cut power to the battery, but kill the car as well. Also, since there is no firewall between the battery and the driver, the battery must be in a sealed box, vented to the outside of the car.
Originally posted by hawgs: Thats what I thought... I am not sure how many people are willing to do that on a car they drive all the time.
The switch is what holds most people back. I don't mind it at all, as long as I can do it tastefully. As soon as I figure a good and clean way to place the cutoff switch, my battery will be relocated.
I ran my 10.8 lb hawker genesis (bought for $28, yes twenty-eight) for a while. Let it sit for 6 months and it refused to work again. Imagine that ... [img]smile.gif[/img]
Throwing it away. [img]smile.gif[/img] Back to the 30 lb $40 walmart special. [img]smile.gif[/img]
