Originally posted by chadder: the tag on my door says 4100lbs!!!!!omfg...no way my car can weigh that much! it has all power and a trailer hitch on it which i cant get off...its bolted really freakin tight. and it has t-tops if that makes any diff at all...
it does say 4100 lbs. if you look though, there is another number there that tells you the packaging weight, it should be like 701 lbs. you subtract that from the 4100 lbs and you get 3399lbs. thats how much your car weighs stock. or should weigh i should say.
quote:
Originally posted by BLLDOGG:
9 seconds is still a long way away but if shirls car went on the attkins diet it would probably be in the high 10s
High 10's??? Nope
I am 400 pounds lighter than her race weight.
It is MUCH harder to go from 11's to 10's than 12's to 11's
________________________________________________
Yeah, highly unlikely, however...... with a loss of 400lbs., I would think an 11.5 or 11.4 might be doable... That's a lot of weight loss though. The only other thing I can think of is replacing stock parts with lightweight ones... ahh, I dunno... I like my car in one piece. I think I've escaped damaged to my car (enough times at the track too) and I like it in one piece.. The only reason I'd lighten it up a little bit now, is for the street when those pesky little Stangs, Vettes and other f-bodies pull up looking for action.. ;)
