Light weight battery ordered - FirebirdV6.com/CamaroV6.com Message Board
  • Light weight battery ordered
    http://www.gotbatteries.com/ProductP...FamilyID=SL167
    http://www.gotbatteries.com/Productp...ctNum=30Z101B1
    This battery weighs 12.0 pounds.
    My current Optima Red Top weighs in at just over 40 pounds
    So, 28 pounds off the nose [img]smile.gif[/img]
    This would take my N/A curb weight into the 2800's.... 2888 is predicted :D
    N/A race weight would be expected around under 3100 pounds :D 3073 expected.
    Nitrous adds 24 pounds per bottle
    Speculation on racew weight w/ nitrous is around 3121 pounds [img]smile.gif[/img]
    Updates shortly
    fyi you can't run lightweight battery in trunk.
    Also, and no offense.. but if you stopped spending $$ on weight reduction and other misc things and finally bought yourself some actual TIRES THAT HOOK you'd run considerably faster.
    Are you racing for ET or MPH. Come on dude, hook it and run new #'s already.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      Nah, battery will be under the hood.
      I'm very confident that I have the right suspension set up FINALLY.
      Also the weight relocation should help.
      I'll be running this saturday and should have new updates
        dude, you're not fast enough to need to tweak your suspension.
        Suspension is not your problem.
        Its tire. If you can't dead hook the tire to cause the weight to transfer all the suspension in the world isn't going to give you a sticker, wider and taller tire.
        FYI, I cut many 1.4's on stock V6 suspesnsion all around. Just had BMR rear LCA's.
          Well, we all know how pig headed I am [img]smile.gif[/img]
          Remember how long it took for me to FINALLY switch to a 3 inch exhaust?!?!?!?!?
          Trust me, I am paying attention to you.
          I know you are cutting mid 1.4's which is crazy.
          I'm not buying tires close to the end of the season. I will run out what I have now and then progress next year.
          What tire/ size would you suggest?
            what tire do you run now?
            fyi, it is SO easy for me to remove engine/trans/pcm now.
            I could very easily just pick up a junkyard V6 setup and spray it into the 10's. If you do not start making me proud I am going to get pissed and just do it myself. ;)
              &lt;taunting voice&gt;You won't do it&lt;taunting voice&gt;
              Just so anyone in this thread can get some ideas James what is your exact suspension setup? You change it enough I can't keep up!
                hehe, and you call that tank of yours light?
                i still say you put soem gear in that thing. it will help you heat real tires and give the car a huge gain down track.
                i will be at slp day if you want any help tuning the suspension. [img]smile.gif[/img]
                later
                tim
                NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
                  tub that biatch [img]graemlins/rock.gif[/img]
                  2000 3.8 A4 Pewter Camaro
                    Well, here is a list of my tire/ suspension set up
                    Nitrous tires
                    Mickey thompson et streets 26 X 10.5 X 16 on camaro salad shooter 16 X 8's
                    N/A tires
                    BF Goodrich drag radials 255 50 16 on camaro salad shooter 16 X 8's
                    Front tires run N/A and nitroused
                    BF goodrich radial 165 80 15's on weld draglite 15 X 3.5's
                    Front suspension
                    No STB
                    No front sway bar
                    stock v6 springs
                    HAL 12 way adjust shocks
                    pa racing mild steel light weight drag k member
                    pa racing mild steel light weight lower a arms
                    stock upper a arms
                    manual steering rack
                    Rear suspension
                    stock v6 springs
                    hotchkis boxed trailing arms
                    hotchkis pan hard rod
                    upper stamped steel pan hard rod thing removed
                    rk sport tubular sub frame connectors
                    rear sway bar from V8
                    D/S loop
                    I wonder if I forget anything????
                    Obviously.. you would have to factor in a lot of weight reduction/ weight relocation too.
                    No A/C
                    No P/S
                    No bumper supports front n rear
                    Bottles relocated into trunk area
                    Light weight small battery under hood
                    Sparco Evo seat, no others
                    The list is endless......
                      28x9x15 ET DRAG on a 15x8 is what I run. If you run that you would be able to spray out of the hole, hook it, and run records.
                        I know you have a torque arm.
                        There are drag swaybars out there although I don't think that's the issue.
                        Like mag said cutting 1.5s spinning on ET Streets is actaully pretty good, with a full out drag tire you're gonna be setting records and hooking hard.
                          NICE [img]smile.gif[/img] ..i just replaced the battery in my car..i was lugging it into the shop to get the core and was like damnit...you could get .05 just by losing this damn thing alone...if somehow your car could run without it lol...good find [img]smile.gif[/img]
                            Ohhhh yeah, ran tech adjust torque arm
                            poly torque arm mount
                            poly trany mount [img]smile.gif[/img]
                              thx for the info on batteries!?!..why couldn't you run that to the trunk?
                              ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
                              • Manimal
                                Coil springs
                                by Manimal
                              • Manimal
                                Newby here
                                by Manimal
