UPDATE: Back from the Re-tune(GRAPH POSTED) - FirebirdV6.com/CamaroV6.com Message Board
  • UPDATE: Back from the Re-tune(GRAPH POSTED)
    Just got done w/the retune with the headers open. The base dyno numbers were lower than my original dyno. First pull made 253.8hp. We ended up getting 3 more HP and it made 256.8hp/249.0tq. The difference could be in air, the dyno corrections, and other small things. They're big fan was broke so they had to use a smaller fan. That could be worth some more power. I know it makes more HP than through the exhaust because it runs quicker down the track but overall im happy with the results. On the last pull we took the belt off to see how much more it would make. It made 271.4rwhp/259.4rwtq. 15hp and 10tq!! :eek: Since I normally make atleast one pass with the belt off. anyways we'll see if it runs quicker as soon as i can get to the track.
    BTW, my rear draglites came in today so next time out ill get to run a bigger tire and leave the line at more RPM. Maybe a low 1.8-high 1.7 60' is coming! [img]tongue.gif[/img]
    http://www.freewebs.com/wickedsix98/dyno.htm
    [ October 12, 2004, 06:16 PM: Message edited by: WickEdSix9838 ]
    Ugh, I'm still dissappointed with my initial results.
    Best of luck
      dang dude. your car is just sick. i would reconsider pushing th limiter up unless you think the motor is prepped for it
      2000 3.8 A4 Pewter Camaro
        Badass Lance. I can see 270 from your car happening with the exhaust opened up! When are you coming to town?
          hard to tune open header cars in closed loop.
          Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
            I will be in town tomorrow evening, atleast by 6! give me a call if u wanna hang out. 432-664-7825
            why is that?
              because your O2's will be contaminated by outsided air and your PCM will continue to add fuel.
              This will be less of an issue with the 3.8 though because the O2's are farther up the stream.
              I think you should be ok as long as you run open y-pipe and not open headers.
                I have work until 5:30, and then work until 8:15 Lance...Looks like a no go for today unless you're there and I happen to make a trip out there to deliver them some parts. Have fun, and definitely drive safe!!!
                  man i wanna come and play too.
                  2000 FIREBIRD NBM<br />Thanks to:<br />TSP, ZZP, TCI, Comp Cam, Whisper, GM, Lakewood, TrafficJamz Car Audio,HP Tuner, Alterstart, texas drivetrain and performance, BMR<br /><br />1990 BLUE CAMARO RS<br />1980 z28 <br /><br />venom-vi vice president
                    The re-tune is at 9 Friday morning Matt.
                    The extensions on my headers are fairly long and ive never had a problem so far. There are pictures on page two of pictures in my site. Hopefully it'll all turn out good.
                    [ October 07, 2004, 10:12 AM: Message edited by: WickEdSix9838 ]
                      I bet you gain more then 4rwhp before tuning just uncapping them ;)
                        i was just going off a formula I have. one tenth is equal to about 4-6 hp...but we'll see in the morning! [img]tongue.gif[/img]
                          Still trying to find oil leak
                          1 day ago
                          Getting some work done on my truck
