ANOTHER NEW BEST!!!(UPDATE) - FirebirdV6.com/CamaroV6.com Message Board
  • ANOTHER NEW BEST!!!(UPDATE)
    I went to West Texas Raceway this weekend again for their Desert Racewars street car race. I turned out to be the only NA 6 cylinder car and there had to be atleast 4 to make a class so i moved to the No-E bracket class. This was the first time i got to try my new 15x8" draglites and 275/50/15 BFG DR's. At first the tires weren't impressing me but as the night went on i guess they were breaking in and started hooking really good. I was launching at 4400-4500 by the end of the night. The air had to be really good. I forgot to take my dads Performaire weather computer this time but i did check it once before i left to go to the track and it showed 4600' DA and 27.25 baro at about 5:00PM. im sure it got down to around 3700-4000'. Heres my passes.
    run #1
    this was through the exhaust, on a hot motor and the new tires, i tried to leave at 4k adn it spun pretty bad.
    60': 2.030
    330': 5.84
    1/8: 8.993
    mph: 78.13
    1/4: 13.954
    mph: 96.77
    run #2
    This pass was with the headers open and the car was really cold so i pulled the belt for this pass. I hit the rev limiter pretty hard on 3-4 shift so i know it killed some ET and probably atleast .5 MPH. When i got the slip i didnt even look at the slip cuz i knew it would be off a little from hitting the limiter. When i looked i was shocked that it ran that quick. I was mad that I had to hit the limiter because if i didnt i would have for sure had the #1 spot on the site.
    RT: .544
    60': 1.913
    330': 5.653
    1/8: 8.7523
    mph: 79.70
    1/4: 13.659
    mph: 99.54
    run #3
    The next three passes i left the belt on and the motor was at operating temp. so i could get a dial in for the bracket race. This pass the tires started hooking better and it bogged really bad off the line leaving at 3500.
    RT .534
    60': 1.9838
    330': 5.8895
    1/8: 9.0642
    mph: 77.63
    1/4: 14.0615
    mph: 97.95
    run #4
    I raised the launch to 3800 and it still bogged off the line.
    RT .545
    60': 1.9317
    330': 5.8100
    1/8: 8.9726
    mph: 78.03
    1/4: 13.9594
    mph: 98.60
    run #5 last TT
    I missed 4th gear this pass but figured the launch out a little more. It spun then grabbed pretty quick.
    RT .539
    60': 1.9043
    330': 5.7653
    1/8: 8.945
    mph: 77.80
    1/4: 14.222
    mph: 83.09
    run #6 Round 1
    This pass i dialed a 13.88 thinking that if it didnt bog the car was fixing to run. I knew the guy I was racing against was a beginner so i didnt hit the tree as hard. He was dialed a 13.05 but he red lit so i hung it out the back door. This is the best pass ive made w/the belt on and the car at operating temperature. After this pass i was wanting so bad to let it cool off and pull the belt for a new best but i still had more bracket racing to do.
    RT .6000
    60': 1.891
    330': 5.698
    1/8: 8.849
    mph: 78.04
    1/4: 13.830
    mph: 98.19
    run #7 Round 2
    This was a damn good bracket race, probably the best ive ever had. The guy had me at the line by maybe a wheel. I dialed a 13.81 to his 11.10 Ill post both of our slips.
    me
    RT .515
    60': 1.913
    330': 5.724
    1/8: 8.878
    mph: 78.06
    1/4: 13.859
    mph: 98.12
    him
    RT .518
    60': 1.614
    330': 4.609
    1/8: 7.048
    mph: 100.92
    1/4: 11.107
    mph: 106.61
    run #8
    After that pass i decided to let the car cool way off and make one more pass w/the belt off to try and get a 13.5. It was almost a perfect pass. I launched at 4400-4500 adn the car hooked better than it had all night w/o bogging or spinning too much. Heres the slip.
    RT 1.5859 <--i was watching the tach
    60': 1.809
    330: 5.5698
    1/8: 8.6743
    mph: 79.63
    1/4: 13.5758
    mph: 99.98
    Timeslip
    these were all new bests! Overall it was a badass day at the track and i love the new tire/wheels combo! After i ran a 13.5 at this track I am almost positive a 12.9 is in the future at sea level! These Abbott Racing Heads are FLYING!
    [ October 24, 2004, 09:07 PM: Message edited by: WickEdSix9838 ]
    good shizzle nizzle...
    GREAT 60s
      awesome [img]graemlins/bowdown.gif[/img]
        i hate you [img]graemlins/bowdown.gif[/img]
        you are now the fastest N/A 3.8 here
        2000 3.8 A4 Pewter Camaro
          Hey WickEdSix9838 I live in Odessa Tx, I was at the last Desert Racewars(just watching). When i heard your car for the first time i thought it was a V8 Formula. I was really impressed when I saw you in the v6 NA. I can't wait to see you at the track again. Nice times you put up.
          (SOLD)<br />2002 Firebird<br />1/4 mile E/T<br />16.1 @ 83.75 <br />(NEW RIDE)<br />2002 Trans Am<br />1/4 mile E/T<br />13.4 @102<br /> <a href=\"http://www.cardomain.com/memberpage/582715\" target=\"_blank\">http://www.cardomain.com/memberpage/582715</a>
            umm i was just thinking about those tires too, wondr if you can pull a less then a 1.5 60' aout of them ???
            nice runs
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              Thanks man! You should have came by and said whats up! Come by next time you see me out there!
              i just read some comments on the new MT Drag radials and by the way it sounds they hook quite a bit better than the BFG's. I'd say u need to try those out!
              [ October 17, 2004, 09:59 PM: Message edited by: WickEdSix9838 ]
                Thanks alot man, I'll be sure to stop by and talk to you. I still can't get over the fact that your taking out some of the Trans Ams at the track. I bet they hate the fact that your v6 can kill them.
                  Originally posted by WickEdSix9838:
                  </font><blockquote>quote:</font><hr /> Hey WickEdSix9838 I live in Odessa Tx, I was at the last Desert Racewars(just watching). When i heard your car for the first time i thought it was a V8 Formula. I was really impressed when I saw you in the v6 NA. I can't wait to see you at the track again. Nice times you put up.
                  were you read that at? got a link
                  </font>[/QUOTE]you got a link were you read it ?
                    http://www.ls1tech.com/forums/showthread.php?t=204661
                    http://www.ls1tech.com/forums/showthread.php?t=227228
                    http://www.ls1tech.com/forums/showthread.php?t=228127
                    http://www.ls1tech.com/forums/showthread.php?t=228442
                    [ October 18, 2004, 12:06 AM: Message edited by: WickEdSix9838 ]
                      Lance, you're the man! 12.9's are without a doubt there at sea-level..Heck, probably even better with negative DA's [img]smile.gif[/img] Rock on!
                      [img]graemlins/rock.gif[/img]
                        Awesome dude!
                        Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
                        "I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
                        http://seppo.hopto.org/
                          Wow didnt know we had this many west Texans out here, I have't been to penwell in a while. I used to live in Odessa, now I'm out in the San Marcos/Austin area. Good times btw [img]smile.gif[/img]
                          99 3.8 Camaro<br />Intake Mods: K&N filter, Whisper lid, free ram air, !air silencer, !maf screen<br />Exhaust Mods: Flowmaster 80 series, 3\" I-pipe, 3\" Cutout<br />Suspension: Intrax Springs (2\" drop)<br />Misc.: Fan switch mod, Hayden transmission cooler
                            Wow! Immpresssive.
                            You have Abbott Racing heads? Never heard of them.
                            <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
                              We usually just do all out race stuff but we've done a few LS1's and my car is the first 3.8 we've done. check out the site if you havent already.
