Try replacing the fluid and see how it responds. While you have the cover off, you can take a look at the gears for anything obvious. Mine whined horribly when I first put them in, but after a fluid change they were fine.
Weight Reduction Pays
2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
Started out around 3450 lbs
Best weight now is 2900 lbs
As for the rear, I have a T/A girdle and stud kit and run synthetic rear diff lube. I change it every year. I grenaded 3 LSD units in 3 years and 1 axle and I'm an AUTO! I run a powertrax locker diff now.Race car - gone but not forgotten - 1997 firebird V6
the fluid thats in the rear has less than 1k on it, its Castrol Syntec synthetic gear oil. Last time i had the cover off they looked good BUT they didnt whine then. I'll probably skip out on running this weekend and check them when I go back home.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Mine is 3600 lbs. with me in it. No weight reduction needed here. Just weight addition...lol2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
James, add some weight back to that car and hit 11's already!! j/k, my prediction is, you'll get it this weekend...2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
