i currently run 14.3s @ 95 mph,i have a cam with 512 lift. how much of a gain will i see if i port and polish the heads and intakes? the car has about 127,000 miles on it, should i seafoam it to?
how much does it help
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
if your going to pull the heads just clean the intake while you have it off...1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by RallyRed 98:
a few tenths? negative... a tenth maybe.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
with teh larger cam the gain from head and intake work will definately show a nice gain. it is hard to say in terms of et since that has so much to do with how well your chassis is working.
i would expect to pick up 20+ hp at the wheels once the set up is all tuned out.
sea foaming it will help it too, not a huge power gain, bu tthe idle quality and mileage will go up.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
thanks for all the input guys. i guess that will be my next mod then. i'll let you know how it goes next race season. stupid snow!96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
i just got a quote from the local machine shop. is 500-600 a good price to get them done. that is for the intakes and the heads to be completely ported all the way through.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
sounds good since you're getting the heads done too...i dont know much but i know that just the new ported upper and lower intakes from supersix are $500 ($80 core)...13s na...that swhat im talkin bout [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by Timmy:
i just got a quote from the local machine shop. is 500-600 a good price to get them done. that is for the intakes and the heads to be completely ported all the way through.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Originally posted by WickEdSix9838:
</font><blockquote>quote:</font><hr />Originally posted by Timmy:
Originally posted by 97rs4life:
</font><blockquote>quote:</font><hr />Originally posted by WickEdSix9838:
fully ported and matched upper/lower intake: $300
mill and CC the heads: $100
SI 1.84" intake valves and 1.55" exhaust valves: $180
milling guide bosses down: free of charge
Comp cam: $299.94
Comp 26918 springs: $128.76
Comp 772 titanium retainers: $119.28
new valve seals $18
Comp High-tech pushrods: $93.00<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
he was going to charge me 700 but he brought it down to 5-600 because its a V6.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
heads fully ported, polished, and completely flowed with our custom 5 angle intake valve job and radius exhaust valve job: $800
Comp cam: $299.94
new valve seals $18
Comp High-tech pushrods: $93.00 [/QB]
Any chance you have flow #'s or pic's before and after?
Thanks!Race car - gone but not forgotten - 1997 firebird V6
yea thanks for the info, now I know roughly how much I need to save up for the engine
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
