i never really looked before and now the track is closed...all the people with real drag radials im sure burn out right in the water box...what about with a fat set of streets?...do you use the water box to burn out?...i usually just burn out right after it...tryin to nail the traction [img]smile.gif[/img]
street tires in the water box?
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
If it has basically any tread what so ever, its gonna kick water up into your fender well and the waters going to drip down onto your tire while your going down the track. If I were you I reccomend going around the waterbox. I wish most FWD vehicles would take this advice as well...
Just my two cents.
Justin
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
1. You shouldn't be burning out with street tires.
2. Burning out in the water box does not heat up the tires. B/c w/ every revolution of the tire water cools it. Not to mention the forementioned water issue.
Ideally with street tires you drive around the water box. Spin them over once or twice to clean the tires off. Then Stage.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
http://seppo.hopto.org/
^^^yeah thats what i usually do...i dont really get a good "burn out"...but i do go around it...just wanted to be sure i was doing it the best way
Seppo...btw...this is off topic but...i was checking out your page...my gears go in wednesday...and im looking at getting the same cam you have...otherwise i have a similar setup...intake, suspension, exhaust...should i get the manifolds too or should i see a nice gain without them?...also...how well do you think nitrous would work with this cam (75 - 100 shot)...any info you could give would be a big help...thanks [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by '98 BlackBird:
I have BFG Drag Radials and I drive though the water box, and do my burnout.
Like Seppo said, street tires dont need a burnout. The compound of the rubber just gets greasy instead of stickier. Just clean them off and stage.
[ November 15, 2004, 09:33 PM: Message edited by: WickEdSix9838 ]<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Seppo and Wicked nailed it! If you drive straight through, you negate any good you do with the burnout by making them drive through other water before the start line.
Also, street tires get greasy when burnt out, not sticky! For street tires, skip the water box, and just spin them nice to knock off any rocks. On a 5 speed you can do this by just rvving, and dropping the clutch...You only need one revelation of the tires to clean them off, so no need to get crazy!<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
You should be fine with the GT cam on the spray. Also I picked up a good 10 rwhp when I added headers. I think that is what you are asking
about.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
sweeeeet...thanks guys...yeah i give em a couple spins outside the box...then i come home with that black sh*t all over the back of my arctic white car lol
Seppo...wow you picked up 10 with the headers??...i've heard that with a cam you get a lot more out of your intake/exhaust...thats why i was thinking of getting the ported intake manifolds too...im gonna see how she does on the cam and spray first...thanks! [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
On my michelin XGT V 255 50 16 street tires I lowered the psi to 28, rolled around the water box, gave a quick snap of the rear tire to clear them off and then let loose!
Now, with my nitto extreme drag radials, bf goodrich drag radials, mickey thompson et streets I roll through the the water box and just a slight snap of the rear tires, NOT SPIN/FLOOR IT!
Each tire, depending on N/A vs nitrous, required different styles of burn outs.
Nitto 245 50 16:
LONG burn out, spin till there is smoke, once smoking wait 7-8 seconds
BF 255 50 16:
Medium burn out, spin till there is smoke, once smoking 4-5 seconds
ET street 26 X 10.5 X 16
Medium burn out, spin till there is smoke, once smoking 6-8+ seconds depending on track conditions, psi etc
If you SPIN/FLOOR it water spins up into the wheel well and after your burn out the water will drip down and you will SPIN BAD off the line.Race car - gone but not forgotten - 1997 firebird V6
^^good info...cuz im actually looking into some new tires for the rear for racing but havent really decided on exactly what to go with yet...thanks [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Well, if your car is a truely daily driver and you MUST drive in the now then look ONLY at a radial tire, drag radials are out of the question.
If this is a car that MIGHT be FORCED to drive through snow once or twice but normally no, then nitto extreme drag radialRace car - gone but not forgotten - 1997 firebird V6
yeah thats the problem...its my ONLY car...right now i have 245/40/18 712s on (i'll be putting my rear snow wheels/tires on shortly)...im looking at going 285/40/18...can i do that on front and back?...or could i only do just the back?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
^^ahhh so you give yourself kind of a little practice launch...i like it [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
