So close...and yet so far... - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Yea, the two-step is a neat trick. It is pretty much only for the M5 guys, because it utilizes the Park/Neutral switch to determine the RPM. This allows him to set his 'neutral' rev limiter to whatever RPM it wants to launch at. As soon as the car starts to roll out, it goes WOT.
    Craig - I still say you should have let us take the belt off. Are you gonna be around tonight? We can test the battery run time over on Whitehead.....
    - Justin
    • #17
      - Justin
      Pull the belt off and it will be atleast .1 quicker, maybe closer to .2! There is definately enough battery power to make one pass and make it back to the pits. There may be enough for two, ive never tried it. Way to go though man, its running damn good!
      • #18
        Originally posted by arthansen:
        I use the same launch technique. It works great. What rpm are you using with the DRs and 4.10s? (is that a 12 bolt?)
        I am using 3000 rpms with street tires and 3.42 and I get very consistent 2.1 60' times.
        That run I set it to 4500, that's with DRs and 4.10 posi. It bogged down to I think something like 2300, so I think I may have to launch even higher.
        2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
        • #19
          Originally posted by 1DangerousV6:
          </font><blockquote>quote:</font><hr />Originally posted by Little G:
          I also found a nice two-step launch technique that I can adjust with HPTuners. Basically I set the rev limiter in Park/Neutral to whatever I want to launch at. As soon as the clutch is engaged it goes back to the in-gear rev limiter (6000rpm). So basically after I am staged, I put the gas pedal to the floor and leave it there until I cross the finish line. Everyone needs HPTuners!
          hmmmmm...nice tip ;) </font>[/QUOTE]ahhhh damnit...figures a sweet tip for my biggest problem area (the launch) is for an M5 only lol [img]smile.gif[/img]
          • #20
            here's a tip....Torque Converter ;)
            • #21
              You will have more then enough bat power for 1 run. I have done 5 runs. I just suggest run with your lights off(keep the e-brake up one click) And turn them on down the track.
              Only thing you have to worry about is the temp of the car, make sure it is at least below the 1/4 hash mark. If you are going to run. If its less its even better.
              • #22
                </font><blockquote>quote:</font><hr />Originally posted by arthansen:
                That run I set it to 4500, that's with DRs and 4.10 posi. It bogged down to I think something like 2300, so I think I may have to launch even higher. </font>[/QUOTE]are you dumping @ 4500? seems like any higher and you'd spin.
                feathering?
                1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
                • #23
                  No, it dead hooks and bogs down to 2300. I am not feathering, not dumping but just kind of getting out of it real quick.
                  • #24
                    He runs a nice sticky tire.
                    4:10's huh? Wonder if anyone else is joining you w/ those ;)
                    • #25
                      Hehehe - GOT HOOK? ;)
                      - Justin
                      • #26
                        wow, sounds like 4.10's OWN. congrats man. i thought about maybe going to 4.10's waaaay in the future if i have another DD and decide to get really crazy with the car. iwould go with 3.73's but am worriwed about mpg
                        CONGRATS
                        V-SEX!<br /><br />intake/exhaust ;)<br />plenty appearence<br /><br />Within my grasp: 14\'s :)
                        • #27
                          My mpg went up, don't fear the gear, my friend.
                          • #28
                            CONGRATS
                            if it hurts your MPG any, it wont be over 1-2, just do it!!!
                            • #29
                              that car is sooo close to the number.
                              crazy people racing has a few tricks up it's sleeve that will get the job done.
                              later
                              tim
                              NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
