How much would it cost to turn an all stock '95 Camaro V6 into a fast drag car? - FirebirdV6.com/CamaroV6.com Message Board
  • How much would it cost to turn an all stock '95 Camaro V6 into a fast drag car?
    I'm just wondering, because I know of a '95 that is for sale for $2,000.
    <a href=\"http://www.picturevillage.com/photo/data/5717490cd17470a679e7b314ba139a95/21019_p262326.jpg\" target=\"_blank\">1998 Camaro 3800</a>
    this is what i have into performance on my car..maybe a couple hundred more..some of this stuff you dont really NEED to drag race though..
    PERFORMANCE:
    Jasper long block w/ cylinders bored & upgraded internals - $4200 - Fredericks Performance
    6 psi Powerdyne supercharger kit - $2000 - fellow V6er
    TurboXS type-s blow off valve - $85 - www.ebay.com
    MSD high pressure fuel pump - $76 - www.summitracing.com
    Functional ram air box kit - $300 - www.rksport.com
    Borla 3" high flow cat back exhaust - $800 installed - www.rksport.com
    Hollowed out catalytic converter - $60 - MVP Motors
    NOS 5175 dry nitrous oxide system - 100 shot - $1000 installed - Z1 Racing
    NOS nitrous oxide purge kit - $100 - www.racerwheel.com
    NOS nitrous oxide automatic bottle heater - $200 installed - Z1 Racing
    NGK TR6 spark plugs dropped & gapped for nitrous use - $10 - Parts America
    Intense Racing PCM file - $100 - www.intense-racing.com
    GM posi differential w/ Motive 3.42 gears & Yukon bearings - $300 - www.ebay.com
    BFGoodrich Comp T/A 255/50/16 drag radial tires when racing
    WEIGHT REDUCTION:
    Removed all carpet/padding from front seats to rear
    Removed all plastic paneling
    Removed spare tire/jack
    Removed all subwoofers/enclosure
    Lightweight racing steering wheel
    Removed passenger side air bag
    Remove passenger seat when racing
    Drain windshield fluid during summer
    Removed front bumper support brace
    SUSPENSION/HANDLING/UNDERBODY:
    Red Hotchkis strut tower brace - $219 - www.rksport.com
    Red Hotchkis pan hard rod - $143 - www.rksport.com
    Red RKSport performance trailing arms - $200 - www.rksport.com
    Red Spohn F&R performance sway bars - $300 - www.fasttoys.net
    Red Energy Suspension poly transmission mount - $30 - www.lmperformance.com
    Red RKSport tunnel brace - $90 - www.rksport.com
    Kumho ultra high performance 245mm tires - wheel/tire package - www.aaarims.com
      He said a 95, which is most likely a 3.4. To make a 3.4 a all out car, go FI or big shots of N20
      1997 Camaro 15.3@91 with a 2.35 60ft-B&M Ripper, SLP Knob, SLP CAI, LT1 DS, EBC Pads. 1994 Camaro(Sadly Sold)-Hi flow cat, custom flowmaster american thunder cat back, KN FIPK, Accel wires, Plat plugs, 160 thermo, Fastchip, Pacesetters.
        I'm at around $15000 and rising
        Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
          basically everything i mentioned can also be used on a 3.4 except of course the blower and block
            first of all, what do you personally consider fast? do you mean fast as in heads up competitive against the average street car? fast compared to stock?
            you can easily get a 3.4 car into the 14's with bolt ons and weight reduction. 13's would, prolly take a mild cam and some head/intake work. 12's woudl require a lot of work.
            if you are interested in trying i am more than willing to help with your combo.
            later
            tim
            NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
              Yup.
              And... you supplied no spec's on this car.
                later
                tim
                What 3.4 are you talking about? Heads and cam would get you mid to high 14's...just bolt-ons got me really high 15's
                Is this a M5 or A4?
                  Originally posted by 1DangerousV6:
                  </font><blockquote>quote:</font><hr />Originally posted by Red94:
                  basically everything i mentioned can also be used on a 3.4 except of course the blower and block </font>[/QUOTE]my bad ive havd a 3.4 fo almost 2 yrs ans just got a 3.8 so im just gettin to know what can be used on both and such
                    Originally posted by White95:
                    </font><blockquote>quote:</font><hr />Originally posted by njspder:
                    later
                    tim
                    Is this a M5 or A4?
                    </font>[/QUOTE]a 3.4 with a proper set up woudl get into the high 14's on externals only.
                    gears, proper exhaust, electric water pump, weight reduction, air intake, and tuning will take you a long way. the tuning and gears would supply the biggest gains.
                    to date i have not heard a whole lot about anyone really putting together what i woudl personally consider a completely prepared car. there are some people with starts on chassis or engine combos that could work, but no one has really put the whole thing together yet.
                    later
                    tim
                      later
                      tim
                      Thats all doable, just put more gear and suspension on a fully bolt on car and it can do it.
                      If your going for the full out "drag car" I'd look into motorswaps, likely na lt1.
                        With Full Exhaust (And Open Exhaust), intake, full MSD ignition, drag suspension, and about 150 lbs of weight reduction got my 3.4 to run a 15.7. There no electric water pump for the 3.4, nor is there tuning for the 3.4 except to fix for gears and minor stuff, nothing to free up a lot of power. And there is no way adding gears to mix would get me into the 14's. If you want 14's out of a 3.4 you have to dig into the heads/intake/and cam.
                          :rolleyes: Yay spending money. [img]graemlins/popcorn.gif[/img]
                            I got 6 tenths out of gears. That and another 150lbs out of your car would have got a 14.9 at least.
                            2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
                              ^yup..i got about 5 tenths out of my gears..and removed 204 lbs..with my drag radials i believe i'll be able to hit 13s on just a 6lb. blower [img]smile.gif[/img]
