Originally posted by White95:
With Full Exhaust (And Open Exhaust), intake, full MSD ignition, drag suspension, and about 150 lbs of weight reduction got my 3.4 to run a 15.7. There no electric water pump for the 3.4, nor is there tuning for the 3.4 except to fix for gears and minor stuff, nothing to free up a lot of power. And there is no way adding gears to mix would get me into the 14's. If you want 14's out of a 3.4 you have to dig into the heads/intake/and cam.
since 95 shoudl still be OBD1 there are plenty of programmers for it. you can correct all timing and fuel tables for your needs as well as correcting other ET helpers like TC lock up and shift points in auto's.
there are a number of inline electric water pumps available. the nice thing about inline is that it is generic and can be adapted to fit nearly any application. another alternative would be to get an electric drive kit.
a real set of gears would prolly help you more than you realize. cars that are underpowered/over weight benefit greatly from correct gear selection. with a 3.4 i would go for a set of 4.56's in a heart beat. car would be a completely different animal after the install.
150lbs is a good start, if you want a fast "drag" car you could easily dump another 200-250lbs and still have a basically full appearing interior. weight reduction is one of those multi benefit things, your et's will drop, trap speeds increase, and lighter cars get better mileage on the way to and from teh track too [img]smile.gif[/img]
i say 14's are there wihtout killing a moderate budget. there is no need to worry about huge head and cam combos to get into the 14's. jsut match up teh rest of teh car and you can get it done.
later
tim
