New best..... pulled a tire off the ground N/A! - FirebirdV6.com/CamaroV6.com Message Board
  • New best..... pulled a tire off the ground N/A!
    First run of the night.... pitiful launch.... pulled the front left tire off the ground 1 inch.... no proof though.
    3 witnesses though :D
    Mr juice being one of them
    New best..... was weight
    W/O driver..... 2850
    W/ Driver...... 3050
    It was cold.... I was wearing a lot of clothing... I'm allergic to the cold!
    Last week..... Bird weighed 2916 [img]smile.gif[/img]
    Ok..... I took care of the "rolling through the lights" problem with my braided steel brake lines.
    Last season.... 3:23's... 3000-3100 stall
    This season.... 4:10's... 2600 stall AT BEST!
    Temp.......49
    Rel Humid..80
    Ab Barom...30.47
    r/t........0.041
    60.........1.915 <--- tire came off the ground!
    330........5.718
    1/8........8.952
    mph........75.62
    1000.......11.766
    1/4........14.149
    mph........94.45
    Could only get to 2,600 off the line.... snapped the throttle.... tire off the ground :D
    Front tires 47 psi
    Rear tires 20 psi
    Front drag shocls all loose
    Rear drag shocks setting 6 (mid way)
    temp.......49
    rel humid..80
    ab barom...30.47
    r/t........0.366
    60.........1.861
    330........5.641
    1/8........8.860
    mph........75.98
    1000.......11.661
    1/4........14.034
    mph........94.82
    2,500 launch
    Front tire 47 psi
    Rear tire 17 psi
    Front drag shock all loose
    Rear drag shock all loose
    temp........50
    rel humid...80
    ab barom....30.47
    r/t.........0.249
    60..........1.893
    330.........5.693
    1/8.........8.914
    mph.........76.00
    1000........11.713
    1/4.........14.081
    mph.........95.13
    2,600 launch
    Front tire 47 psi
    Rear tire 16 psi
    temp........49
    rel humid...80
    ab barom....30.47
    r/t.........0.127
    60..........1.898
    330.........5.684
    1/8.........8.903
    mph.........76.01
    1000........11.702
    1/4.........14.071
    mph.........95.02
    2,600 launch
    Front tire 47 psi
    Rear tire 16 psi
    temp........48
    rel humid...82
    ab barom....30.47
    r/t........-0.240
    60..........1.970
    330.........5.777
    1/8.........9.013
    mph.........75.61
    1000........11.823
    1/4.........14.203
    mph.........94.63
    2,600 launch...tried to go higher...spun off line
    Front tire 47 psi
    Rear tire 15 psi
    temp........47
    rel humid...88
    ab barom....30.47
    r/t........-0.106
    60..........1.914
    330.........5.738
    1/8.........8.994
    mph.........75.17
    1000........11.819
    1/4.........14.209
    mph.........94.23
    Front tire 47 psi
    Rear tire 15 psi
    So..... new best weight 2850
    Pulled a tire off the ground :D
    Took care of "roll through light" problem
    Found stall problem.
    My Proyank 3200 stall was custom made for my mods at the time.... 3:23's.
    Last season with 3:23's I could see 3000-3100 off the line.
    I now have 4:10's (which is the ONLY change) and can only get to 2,600 MAX then the rear tires start spinning.
    I've lost 400-500 rpm's off the line (stall speed) but have maintained N/A times.
    My guess is..... I need a higher stall converter.
    I will contact Yank tech line Monday and speak with them and see what they say.
    [ March 26, 2005, 12:35 AM: Message edited by: 12secondv6 ]
    sorry, but I have a hard time believing you pulled a tire off the ground with a 1.9 60
    98 Firebird. See it here: <a href=\"http://www.burnoutbrigade.com/BBchrisb.htm\" target=\"_blank\">http://www.burnoutbrigade.com/BBchrisb.htm</a>
      If he was gonna bullsh*t, he would have thought of something better than that.
        I'm not trying to call BS but I just have a hard time believing a car that trapped 94mph can pull a wheel.
          GOOD damn!!! how much have you taken off that car?(or would it be easyer to list whats left on the car [img]tongue.gif[/img] )
          when I weighed my car it was 3162 with 1/4 tank
          Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
            Me too.
            I was hoping for video/ photo proof but don't have any :(
            Would I lie about this though?
            Factor in:
            2850 pound car
            High stall converter
            Drag suspension
            AWESOME weight transfer/ relocation/ reduction
            My suspension/ drivetrain:
            PA racing mild steel drag k member
            PA racing mild steel lower a arms
            QA1 drag shocks front and rear (set to all loose)
            rk sport tubular sub frame connectors
            boxed hotchkis trailing arms
            hotchkis pan hard rod
            upper pan hard rod removed
            v6 springs from and rear
            random technologies adj tq arm -2 degree's
            weld drag lite 15 X 3.5's
            165 80 15 tire in front, 47 psi
            camaro salad shooter 16 X 8's in rear
            bf drag 255 50 16's in rear 20 psi rear
            proyank 3200 stall converter (saw 2600 :( )
            built tranny (for 10-11 second cars)
            4:10 gears
            power trax locker
            t/a girdle and stud kit
            programmed computer
            I'll try and get video proof... next time
              Originally posted by wolf:
              </font><blockquote>quote:</font><hr />Originally posted by 12secondv6:
              </font>[/QUOTE]Stock..........now
              3,450..........2,850
              600 pounds gone!
              http://www.ls1tech.com/forums/showthread.php?t=17319
              I've done many of those mods!
                Also.... look at humidity.... ranged from 80-88!!
                Higher humidity = slower car too!
                  i was there, i saw the whole thing, he pulled the front left tire off the ground. we arent talking 3 feet off the ground but about an inch i would say. so it aint BS.
                    They're gonna say... "Show us the $$$$$!!" [img]tongue.gif[/img] The humidity was horrible... that was last night?? Today's a much nicer day.. Take that back... it WAS nicer in the morning/early afternoon..not anymore..
                    [ March 26, 2005, 06:02 PM: Message edited by: Shirl ]
                    2004 CE Corvette 10.86@132mph
                    2011 Cadillac CTS-V
                    2006 Mitsubishi Eclipse GS
                      nice run...
                      as for lifting a tire, doesn't completely matter about power. I have seen cars that run like 16s, pull a wheel, oyu get technical, my dad's old 13.5 hp riding lawnmower would lift the front wheels when you popped the clutch.
                      Its about weight distribution/transfer, traction, and the "shock" of power off the line, not so much power.
                      Congrats on it...
                      as for you guys and your "race" for weight reduction its nutz
                        besides..from what i've read people would swear they saw light under your tire years ago..nice runs..i cant wait to see what times the new converter brings!
                          congrads but stop wasteing your time with N/A runs, spray that old cow!!! :D
                          2000 3.8 A4 Pewter Camaro
                            Moooooo
                            2004 SRT4<br />2006 Mercedes ML350<br />1988 IROC - Supercharged and stuff
                              with a car that light im not suprised at all ... keith (magnus) used to pull a wheel off the ground when he had the V6 didn't he?
