another quick question..when you're at the line stalling..do you have the arming switch on and ready to inject as soon as you hit WOT (since you're already at rpms high enough to inject), or do you launch first and then flip the switch?..thanks!
Spraying with the TC (again)
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
cool..i actually sent my edge back..James and Keith sent me in the direction on a Vigilante..but they're REALLY expensive so im tryin to pick up a used one..probably not as high though..id like a 3200 [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I allways spray out of the hole with my 3000 edge converter i had Comp adj. drag shots. BMR trailing arms and panhardbar and boxed subframes and used Nitto 555r and MT ET streets and tration was never a problem. i loved cutting 1.6 60 foots the feel so good. Burnout is key if i felt like they didnt lay down engough water i would actully hit the nitrous for a sec during burnout to ensure my tires were hot. Then a nice long purge so that i get a strong first hit. I kept my bottle pressure @ 1100-1300 psi.<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
^i was stalling to 2000 and spraying asap last time i was out and have no trouble with traction so far..they practically lay down water after EVERY run..obviously a wet shot will be different..bottle pressure was a HUGE problem though..could only get it to 800 - 900 psi..but i've got that fixed now [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I would lay my bottle in bathtub with hot water for 25 mins before i left then put it in car with warmer on for the trip there. to maintain pressure i would stall to 3000 and let her rip with my lightened front with skinnys and no front sway bar one of the front tires would come off group such a great feeling<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
sweeeeeeet..i fixed the pressure problem..just got the bottle filled..turned on the heater..and the pressure went from 800 to 1100 in just under 20 minutes..then i shut it off..so the spray should be fine now..now i just gotta get a TC in there..put myself well into the 13s on just juice [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I stall to 2900-3000 rpm's..... light goes... I floor it....go WOT... then hit nitrous.
Basically, off the line.
Why get a converter? Keep it stock and focus on your current set up.
It took me almost 1 yr to learn my verter.... and I'm no newbie to drag racing.
I went 12's on a stock verter.Race car - gone but not forgotten - 1997 firebird V6
right..i want to get as low as i can on the stock verter and juice first..but i know i will be putting one in at some point..even the edge wasnt going in for a while due the the install cost..im focusing on just tuning the juice..if i see a good deal on a used one i'll probably go for it..but it may not even go in until next season..with some good tuning id like to hit 12s on the stock TC as well [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I went 12's on a stock verter.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
