no sway bar = boat
i got a 13.338
Originally posted by shenanigans:
doesn't hurt nothing but your car will handle like ***...
feels more like a pickuptruck, and is more prone to get the tail out.
I have gone a month or two without it, its not that bad, but I can't stand not having a car that handles decent.
I did run without a swaybar for awhile it was fine under normal driving, but def couldnt take a corner. I have no experience with an fbody though.
I say take it off for the track if you would like, but if you care at all about handling, I am sure you will want to put it back on. [img]smile.gif[/img]92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
work on that nitrous before worrying about things like removing the sway bar..you're getting about 1.5 seconds out of that 100 shot when you should be able to get around 2..maybe more..there's still a lot more to be gained there..go back set up the same way..log some runs..and just keep practicing [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
My car hadnles just fine without hte front sway bar. i havent had it on since i did the swap. it still turns. the front end is a lil loose. i dont recomend it for a daily driver. but it saves about 10-30 lbs off the front i cant remember how much it weighs.
it doesnt handle like a boat. i have about 500-800 miles (spedo isnt connected guestimating this)
and i havent noticed a single problem.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
ok ill shut up now lol,
you have to start trying new ways of launching the car, to see what method netts you the best/better 60's IMO2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
Originally posted by 1DangerousV6:
go back set up the same way..log some runs..and just keep practicing [img]smile.gif[/img]92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
ohh and actully she should be worrying about her launches more so then her nitrous
she has heads and cam and pulled a 2.0 60' she should be in the 1.8 1.7 on spray atleast if not faster then that if she pulled a 1.7 all else being the same that should drop her .6 sec alone
pull the front sway it deffinetly helps the launch by transfering weight to the wheels.
also I dont know what rear tire you are using but if you are on those c5 rims those are not helping
run stock 16" if you can with a drag tire atleast
couple friends have seen a .4 diffrence going from a 17" tire to a stock 16"
smaller tire = taller gear also lighter probably
I think you should get the 2 step and go out and just practice n/a if you cant pull 1.8 with heads and cam with a good launch and traction some thing is wrong you need to work your launch out
little g pulls 1.8's with his stock motor you have to atleast have 20rwhp more then him so you should be able to pull atleast a 1.8 when you can pull 1.8's then I would spray but you may need more tire at that point I dont know if a drag radial will be enough
Originally posted by RedFrk13:
</font><blockquote>quote:</font><hr />Originally posted by 1DangerousV6:
Kristen..gotta update your bragging rights on your cardomain [img]tongue.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Originally posted by njspder:
just a few bolts, if you don't like it you can throw it back on in 10minutes anyway.
later
tim00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by kristen:
what do you think i need slicks?
You need to keep working on the suspension and the tune. Why you wouldn't want to launch off the 2 step is beyond me. Besides, I don't think it is something that you can turn off, there will always be a P/N rev limiter, it just depends on where you set it.
If I were you I would run NA until you are consistently getting the ET and mph that you should have for a heads/cam/tune car. Then work on the spray. It's not as glorious at first, but once everything is working correctly, you'll have a well setup car that lays down fast times. [img]smile.gif[/img]
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
- Justin-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
i thought you already did your suspension?..id get a set of lower control arms, and adjustable torque arm set to around -3*, a pan hard rod..and maybe weld-in subframe connectors..i run drag radials and spray off the line right at WOT..last time out my nitrous was only working off the line cuz of a leaking hose..but i got mid 1.8s - low 1.9s 60's every run<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
