ok got a question for you all. please list what you keep your front tire psi at, your rear psi, what rpm your launch at, how you shift off the line and how you shift in the race.
all drag racers
Front tires ~35. I start the rears at about 28 and work down as needed. Launch somewhere around 2500-3000.Matt
1998 Mystic Teal Camaro M5
this is very siubjective. different tire brands, suspension mods, and launch technique can allow any number of tire pressures to work on a given night.
front tires you should air way up. 55-60psi while racing.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
I normally dont raise my skinnies over 40 PSI because they're cheap tires and I'm skerred. I normally run my rear 275/50/15 BFG DR's at 16 lbs hot. The launch depends on the track conditions. Average launch RPMs is probably 4500-5000 but on good race days, I've lauched as high as 6200 dumping the clutch. My best 60' is a 1.74.
[ June 10, 2005, 07:19 PM: Message edited by: WickEdSix9838 ]<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
front 165R15s at 60psi, rear BFG DR 235/60/15s at 22.5-24psi cold, 5000rpm launch quick feather of the clutch.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
I keep front tires at 34psi and rear BFG drag radials at 23 psi.
I launch at 2200 with a 2800 stall and let the computer shift for me ;)New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
i run my fronts nitto ep 455's 225's at 45-55 psi. all depends on how i run with them at the lower but i like to usulaly run around 48 psi in the front
my nitto EP 455s in the rear 245's are usually at 23 wheni run. streets shouldnt go lower then 22 at the strip. even slicks i wouldnt go lower then 16 on. 16 means u gotta do a mean burnout to even out the tire so u dont spin off the line. around 22 should be what u run at the track in the rear. i launch at 1100 and a slowly roll off the lights and i slowly nail the gas. as to try not the break lose. but yet everytime i spin. 500hp +lil tires = No Traction Nomatter what.
i shift on my own. cant rely on a old school auto. it would shift to early on me. as i shift at 6100-6300.
my tires break from 1-2 for about 20 ft. and from 2-3 for about 15 ft. i shift into third at around 6000-6200. but i have a turbo 350 trans. and a 3.08 open. next friday im putting in my 3.42 lsd rear end. gunna run some nittos' 275's on a set of 17 light weight racing wheels. and see how it hooks and runs. this will be what i need to get low 12s instead of low 13s i cant hook at all.(next im investing in some DR's id runt hose at around 21-20psi. but the frotns shouldnt be bellow 40psi.
its ok to runt hem at a higher psi as this creates less friction and its a short distanc.e so the tire will not heat up to much. =safer to run higher psi. 60 would be the max i would ever go with fronts. on street tires. (not cheap street tires such as a reg car tire on performance tires) (tires made for cornering ect that have a firmer sidewall.)<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
not that it matters since most of you run better rubber.
I been running 245/50/16 Yokohama avs100s
i run 45-50psi in teh fronts ~32 psi in the rears.
i been launching from 3300-3700 rpms.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Front 50 psi on my regular street tires
50-55 psi on the skinnies
Rear BFGs G-Force DRs start the PSI at 19 and go from there, whether im spinning or not
launch at 4500 slipping the clutch out
*Note* Unfortunatly Im a V8 but you already knew that lol
-Brandon2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
as am i brandon. sbc carbed. ur ls1 powered.
iu duno about any of you but i normally operate my tires at 32-35 psi. what do u guys normally runt hem at for the street?<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
around 35 - 40psi in the kumhos up front
25psi in the BFG drag radials on the rear
i inject right off the line
i stall to 2000rpms..unless i flash the converter then i can launch a little higher<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
i run 32-34 in rear
fronts i run 34-35 psi daily driving2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
