60 ft times - FirebirdV6.com/CamaroV6.com Message Board
60 ft times
  • 60 ft times
    How do I lower my 60 ft times?
    My timeslip is
    r/t .105
    60' 2.406
    1/8 10.013
    mph 72.88
    1/4 15.315
    mph 93.34
    Thanks guys!
    1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
    Practice.
    Matt
    1998 Mystic Teal Camaro M5
      some suspension work and good rubber will help
      2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
        first thing to do is get yourself staged properly.
        you want teh car as shallow in the beams as possible and you want it there consistantly.
        pull forward slowly until you turn on the top set of lights, then stop. then, using the gas and brake at the same time, creep the car forward very very softly until the second set of lights just comes on and stop.
        you will also want to practice with how the car wants to be launched. push down hard on the brakes and rev it to different spots before you launch. whichever rpm creates the best 60ft is your answer.
        the big thing is to be consistant. if you can replicate all the things you do leading up to the launch it will be easier to see improvements from changes and easier to spot areas that need improvement in the future.
        later
        tim
        NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
          Go faster
            Practice.
            That is key.
            With practice you can:
            read the track
            know what 1 psi diff does in a tire
            know X amount of gas affects traction
            launch rpm affects 60 ft's
            Check all the threads with "!" in them
              you can also try flashing the converter..i only do this if the track is prepped REALLY well (otherwise i just stall to about 2K rpms)..basically you just stall to a couple hundred rpms above idle..then when you launch just floor it..if done correctly it can give you a launch at a higher rpm..track prep has to be really good and you'd probably want a set of drag radials
                I'd hold off on the drag radials...
                Just practice it... hold gas, hold brake, let off at an rpmy that suits you.
                maybe put the rears ~28 psi, Drive around the water, definitley spin them a bit to get the dirt off your tires. A few times and you should start getting a feel for it.
                I wouldn't suggest throwing money at the car right away.
                  Yup, people don't realize how much they can learn/ go quicker.... with just practice.
                    Put me in the drivers seat.
                    Past Ride
                    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
                    (If you dont know me, you haven't had a V6 long enough)
                    Current Ride
                    2006 Mitsubishi Evolution GSR
                    www.myspace.com/shane1015
                      Originally posted by Shane:
                      </font><blockquote>quote:</font><hr />Originally posted by 4thgenowner:
                      Put me in the drivers seat. </font>[/QUOTE]no no no put Brink in teh drivers seat [img]graemlins/rock.gif[/img]
                      1997 Camaro 15.3@91 with a 2.35 60ft-B&M Ripper, SLP Knob, SLP CAI, LT1 DS, EBC Pads. 1994 Camaro(Sadly Sold)-Hi flow cat, custom flowmaster american thunder cat back, KN FIPK, Accel wires, Plat plugs, 160 thermo, Fastchip, Pacesetters.
