"BANG" on launch - FirebirdV6.com/CamaroV6.com Message Board
"BANG" on launch
  • #16
    You are so in trouble!
    How many passes did you make with this banging sound?
    If you hear it once.... get under there and check it out.
    Could be D/S hitting D/S safety loop.... and slowly gouging into d/s weakening the strength of it.
    Exhaust hitting underneath of car
    Bad tranny mount
    You are in trouble!
    When you coming up here again? [img]smile.gif[/img]
    • #17
      Okay we got the car up last night.
      Exhaust was all broken loose in the back, just a rubber hanger keeping it there. That's welded back up (more or less). Sad thing is... at some point the over-axle pipe must have hit the axle really hard and it cracked the pipe, so that's gotta be replaced.
      Seems the noise was something between the pipe hitting the axle and the drive shaft hitting the I-pipe.
      Made some fuel adjustments, still having some problems.
      James, you don't want none of this car [img]tongue.gif[/img]
      ... but I could think about a tnt day. ;)
      • #18
        poly trans mount and adjustable torque arm. did i say poly trans mount and adj torque arm? LOL
        just one more thing, you are slow... that is all. ;)
        ~Jessica~<br />Office Manager @ <a href=\"http://www.fbodycentral.com\" target=\"_blank\">http://www.fbodycentral.com</a> <br />2001 Firebird GT NBM, A4<br /> <a href=\"http://fbodyqueen.tripod.com/\" target=\"_blank\">http://fbodyqueen.tripod.com/<
        • #19
          Little girl..... don't make me beat you N/A!!!! [img]tongue.gif[/img]
          Waits at e town patiently ;)
          • #20
            *YAWN* ....
            Call SLP & E-town .. make sure they know there's a match race coming up on Oct 8 ... best of 5 sound good to you? [img]tongue.gif[/img]
            • #21
              Best of five huh?
              You are mine!!!! [img]tongue.gif[/img]
              • #22
                Originally posted by 12secondv6:
                You are mine!!!! [img]tongue.gif[/img] [/QB]
                Hey if you want her you have to Pay Pal me 20 bucks seeing as I still own her from A.S.S.
                03 GTP Sedan<br />Pulley Boys Qwik Change hub and 3.4 pulley NGK TR6s Blue Taylor wires Hyper suck 160 stat FWI with 9\" cylinder K&N 11.9\" Rotors KVR pads Clear Front Corners Tint13.56 @ 101.21 mph 2.02 60\' <br />Best 60\' 1.97 on Eagle RS-As
                • #23
                  If the bang is still there, Are you getting any SES codes, it wont throw the light the first time. It must cycle. So you will have to scan it. If the tranny is slipping, it will demand max line pressure on the 1-2 shift. It will feel like a huge bang, if you are taking off hard enough.
                  Its decieving because it won't throw a code untill it happens after two cycles of starting the car.
                  Cardomain
                  • #24
                    She has a 5 speed
                    • #25
                      The "bang" was two exhaust hangers snapping, causing the over axle pipe to smack down on the axle... so now that needs fixed too.
                      • #26
                        Originally posted by GTPNutJob:
                        </font><blockquote>quote:</font><hr />Originally posted by 12secondv6:
                        ;) [/QB]</font>[/QUOTE][img]graemlins/rofl.gif[/img]
                        • #27
                          Would have been a dollar but I need exhaust work. I got a feeling I won't get anywhere near 20 in the end though
                          • #28
                            I've seen taht problem before, it was a cracked rear sway bar that was loose and bumbing against the bottom of the car
                            1999 y87 a4, american thunder cat-back, 3.42 gears, headers, grey racing stripes, billet grill, 17inch c5 rims
