Exhaust was all broken loose in the back, just a rubber hanger keeping it there. That's welded back up (more or less). Sad thing is... at some point the over-axle pipe must have hit the axle really hard and it cracked the pipe, so that's gotta be replaced.
Seems the noise was something between the pipe hitting the axle and the drive shaft hitting the I-pipe.
Made some fuel adjustments, still having some problems.
James, you don't want none of this car [img]tongue.gif[/img]
If the bang is still there, Are you getting any SES codes, it wont throw the light the first time. It must cycle. So you will have to scan it. If the tranny is slipping, it will demand max line pressure on the 1-2 shift. It will feel like a huge bang, if you are taking off hard enough.
Its decieving because it won't throw a code untill it happens after two cycles of starting the car.
6 days ago
