yea pull the sway bar, and pull the passanger seat its heavy and only hase 4 bolts and 2 screws that hold it in, very easy to take out. your not just trying for 12.999 you want as low as you can do what it takes to get there
Racing tomorrow..need advice
eh..from my logs it looks like it injectss at about 2700 rpms..for a dry shot..that sgood enough for me..and what gave me that 1.7 60' ;) ..anwyays..i dont think im gonna be out this weekend..tomorrow is supposed to be a record breaking high temp of almost 100* ..and its supposed to be over 90* on sunday too..so i think i may save the juice for wednesday night..it wasnt bad last time i went..on the runs where i was pulling timing i cut a couple 1.9 60's and probably couda done better but i was really out just to log..anyways..with those temps it would just suck @ss this weekend<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
dude every time i watch the weather its tripple digits in AZ..the heat makes me sick if im in it too long..you guys are crazy..i dont think i could survive there! lol<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
i whish you luck and may the force be with you94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
u need a Tubular Crossmember 80lbs of the nose94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
Originally posted by rudy q:
u need a Tubular Crossmember 80lbs of the noseRace car - gone but not forgotten - 1997 firebird V6
Originally posted by 12secondv6:
</font><blockquote>quote:</font><hr />Originally posted by rudy q:
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
Using our tubular K-member and upper/lower a-arm set, expect a weight reduction of 85 lbs
STRONGER, and LIGHTER than stock! (loose over 75lbs)
this is what is on full throttle performance said has any body ever weight a stock k-member94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>
Well, considering that a stock k-member weighs 45 lbs by itself and another 45-50 for all of the a-arms, I don't see how you can lose 85 lbs with an aftermarket one. And yes, if there is anything that I would know, it would be the weight of parts on these cars. ;)
PA Racing mild steel drag k member and mild steel lower a arms
Exact weight reduction #'s are posted somewhere in the drag racing section by me.Race car - gone but not forgotten - 1997 firebird V6
