12.82@103 ..WOOHOOO!! - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Don't forget, Steve's car is heavier compare to James. Which probably looks like a shell now.
    Big Congrats on reaching your goal. Now how about that 11 sec.?
    • #32
      Originally posted by njspder:
      he doesn't need nitrous help, he needs tuning/chassis help. he has proven he can hook up a kit properly at this point. [img]smile.gif[/img]
      later
      tim
      tim...craig has trapped 99mph with less then 225rwhp lol how is it his built motor only traps 103 with a 225 shot over and above his NA combo? There is something wrong and i wouldnt start with his suspension [img]graemlins/stickpoke.gif[/img]
      00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
      • #33
        Yeah...something is very wrong. I mean...that car should be deeeeeep into 12's, and probably in the 11's. It has to be putting down around 400RWHP...and about 450RWTQ. That is absolutely plenty for 11's.
        • #34
          Actually, he has done extensive weight reduction.... he is probably around 3,000 + lbs.... only 150 pounds more than me
          • #35
            later
            tim
            225 shot?!?!?!?1 And these results??
            And you say doesn't need nitrous help?
            He could due to have some nitrous help.
            • #36
              i dont speak spanish so i have no clue wtf you just said there but you & I both know tim...if it cant be fixed with taking out weight or adding LCA relocation brackets there is no fix to the problem [img]graemlins/banana.gif[/img] lol
              • #37
                Well, I think the fact that there are severe issues with the tune is already very well documented. But he should be cutting consistant 1.7s or better with a 225 shot. The car has issues all over, not just in one specific area.
                - Justin
                • #38
                  - Justin
                  I think our point was running 103mph with a shot that should be giving him over 400rwhp theoretically is more then suspension...mph is going to reflect how much power your making...get that worked out then work on your suspension...theres no reason he shouldnt be trapping 110+ spinning through the first 2 gears.
                  • #39
                    - Justin
                    Like I said.....
                    • #40
                      Hmm, I wonder what a 225 shot would do to my car...
                      g
                      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
                      • #41
                        It should be putting down 400hp/450tq but I am sure its not. Tuning all the way around is the problem. He runs those heavy a$$ wheels, won't remove this front sway bar and who knows about the custom tune. As I said before, there is more to this game than just throwing money at a car. I mean, he had two different avenues to choose. Run the 150/175 sot and figure out what is wrong or throw more money into it just to make it go a little faster. So he throws a second stage 50 shot on it to go 3 tenths faster. 1DV6, just pause and think about it. I know tuning can suck but you need a little patience here.
                        • #42
                          Originally posted by Jerriko:
                          </font><blockquote>quote:</font><hr />Originally posted by TheGreenPunisher:
                          It should be putting down 400hp/450tq but I am sure its not. Tuning all the way around is the problem. He runs those heavy a$$ wheels, won't remove this front sway bar and who knows about the custom tune. As I said before, there is more to this game than just throwing money at a car. I mean, he had two different avenues to choose. Run the 150/175 sot and figure out what is wrong or throw more money into it just to make it go a little faster. So he throws a second stage 50 shot on it to go 3 tenths faster. 1DV6, just pause and think about it. I know tuning can suck but you need a little patience here. </font>[/QUOTE]I could not have said it any better myself.
                          <b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
                          • #43
                            g
                            it would probably spill its guts at around the 330' mark lol and because you'd be spinning al the way to it you wouldnt run a better # either way ;)
                            • #44
                              g
                              You could be in the 10's the way you drive...
                              • #45
                                </font><blockquote>quote:</font><hr />Originally posted by Little G:
                                g
                                You could be in the 10's or deep 11's the way you drive... </font>[/QUOTE]
