Im Going back to the track - FirebirdV6.com/CamaroV6.com Message Board
  • Im Going back to the track
    tommorow's going to be my first time at the track with the new rear end, and since may. hopefully going to run the mid 12's i should be running. i ordered some drag radials yesterday im gettign them mounted before i go to the track tomoro. that should get me down fromt he 2.8 60' to maybe a 2.2 lol which should lower my et quite a bit and should at least give me traction for my 2-3 shift at which i break lose in just like the 1-2 i break hard in. and first gear is just a tire warmer pretty much. all theyd o is spin through the whole gear. ive ditched the 3.08 open and went with a 3.42 lsd and ta cover,
    hopefully ill be running what i should be the new gears pull alot harder. and they coast alot better then the 3.08s did on the eway the 3.08s seamed to slow me down the new gears stay in the rpms better even if im at 3 grand doing 60 mph on the expressway. i go 70 or 80 and eveyrone starts looking at me cuz im at 3500 coasting along waaawawawwawaaaa rrrrrr louder then hell. i love the way its pulling. and going from opent o lsd is a huge difference. the new gears break the tires lose in the 1-2 at a shift from 2 grand and up. i could only imagine what a 4.11 would do lol.
    but wish me luck. hopefully ill be able to actually launch it from the beams instead of slowly roll forward and slowly touch the gas. and still spin everwhere.
    <a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
    I'm confused, is the swap done? I am guessing it must be if you are going to be hitting 12's
    Good luck.
    1996 Camaro Y87 5-Speed<br />K&N filter<br />15.19 @ 89.84
      the engine swap is done i aint changed that in a while i finished it back in march. ive finally finished my car friday witht he new rear end. all and all imd one till i get enough money to go with a stroker crank and go with a new paint job.
        the current mods are 3.4L! ECU! 4L60! Open Rear end and low gears! AC!
        I added a gen I sbc 350 its competely worked. forged bottom end. 230 230 cam with 292 advertised and 512 lift on both. its carburated. single plane intake. th 350 trans the engine is .040 over its decked. iron eagle heads. lt1 LT headers. one piece liht weight steel driveshaft. 3.42 LSD rear axle with TA cover. disk brakes all the way around. everything fitrs under the stock hood. true dual exhaust with two bullet mufflers. dumped right in front of the rear axle. pretty much full bmr suspension. SFC LCA Track Pack. Trans cross brace, Kmember. i still need a few more things from bmr but its all laer downt he road its not needed cars fine and setup fine without it.
        trans is completely built and pretty much bullet proofed.i set the valves on the car every 2 weeks as i like to keep them loose ocassionally ill tighten them up
        ive got a deep trans pan and oil pan. ground clearence doesnt exist.
          So can you drive on the street? Or must it be trailored now? I think that car would be one hell of a punishing ride on the street!
            its on the street baby i love it. the other day with the 3.08 rear end. a 03 cobra wanted to play on the eway. i put him 4 cars back and laughed my *** off the whole time he kept coming back for more. its loud as ****. but i mean u dont know whats under the hood cuz it all fit.
