what suspension should i do first? z rear end and lca's and t orque arm>?
stupid question
swapped your gears yet? if you've still got 308's or 342's id get rid of them.
Originally posted by Camarorulz:
any 14 second timeslip with that setup is VERY optimistic. I would say 15.5 and below. That's the best estimate you can really hope for. I don't know what the humidity, weather, etc. is like in Washington but hope for a mid-15 or less. Driving skill is also a factor with a 5-spd.1997 Camaro 15.3@91 with a 2.35 60ft-B&M Ripper, SLP Knob, SLP CAI, LT1 DS, EBC Pads. 1994 Camaro(Sadly Sold)-Hi flow cat, custom flowmaster american thunder cat back, KN FIPK, Accel wires, Plat plugs, 160 thermo, Fastchip, Pacesetters.
Originally posted by Yaba3800:
yeah i think i have 3.23's i want a z rear end with 3.73's
latere
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
it is only a difference of about 250rpm at 70mph.
most times when gears are installed in cars mileage will stay the same or go up. a little bit more rpm will put the engine in a stronger area of teh torque curve, that means you will use less gas peddle to go the same speed and with the gear advantage there is less effective load on the engine.
for the 1/10th of a mpg you may lose the 1/10 of a second you will knock off your et iws worth it. gears are your friend [img]smile.gif[/img]
later
3.42 gears = at 60mph my rpms are at 2500rpm
njspider, are you sure youre trying to say 250rpm?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
yaba3800 is on the right track.
cruising is not hard on mileage or your engine. it represents low load which is not what eats up fuel. acceleration and sitting at lights kills gas mileage a lot more than a good set of gears ever will.
later
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...6 days ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
