Anybody have any tips to run a better time? Tire psi, quick weight reduction, unfilled tank and things along that line?
Track Day Tips
Track Day Tips
<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>Tags: None
fron tires atleast 45, back around 28-30
lose the spare tire and jack. ditch the seats cause they come out quickly. ditch the acc. belt if you want. you can get a siphon from walmart or whatever for like 10 dollars and damn near drain your tank into a gas can.
How do you take out the seats?
I heard uninstalling them was difficult...<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
its like 4 nuts and a connector from the wiring harness if your running power seats.
The rear seat back weighs 13 pounds. I'm not sure about the passenger seat but I'd imagine it's less than 25 unless you've got power, which was an 8 pound addition. Every little bit helps I guess, but that's only about a .04 difference in time.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
if you're running street tires make sure to avoid the water box..and dont burn out..burn outs are for drag tires only..just give them a quick spin before pulling up to the line<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
burn outs are for drag tires only..just give them a quick spin before pulling up to the line<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
Street tires are designed to grip in normal outdoor temperature ranges, especially all-season tires. Drag radials and slicks use compounds that are designed to grip at hotter temps. When "cold" they don't have the same amount of bite, thus you have to heat them up by doing a burnout before each run.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
^precisely..so thats correct..no burnout..just give them a quick snap before you pull up to the line to clean them off..check the pressure in between runs too..as out door temp changes so does your tire pressure<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Check the threads w/ "!" in them.
Street tires.... drive around the water box, quick stab of throttle to clean them off and then go race.
I'd suggest 28 psi in the rear and 45 in the front.
Keep the hood open in between rounds to cool down the engineRace car - gone but not forgotten - 1997 firebird V6
whats the best RPM to launch at without too much spinning? i usually have mine around 2-2.5. that sound about right?'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
the most you can get without spin..some cars prefer to have the converter flashed<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
also I keep the rears at 32-34 psi, and work them down, see if the edges are hitting the ground or not, and adjust. But most street tires work best for me 30-34 psi.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I posted this in a couple other threads, probablly saw it already but anyways heres a 3500 launch..
http://media.putfile.com/09048<b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
Practice with tire psi, amount of gas in tank and track prep to see what rpm is perfect for your car on that day at the trackRace car - gone but not forgotten - 1997 firebird V6
