Hello out there. I have a 1998 camaro with various mods but most are suspesion. I have added strut braces, lowering springs, struts, control arms f+R, and 245/50/16s. I want to add sway bars but have heared that they can throw off your balance more then help. so if ya have a pointers then send them my way. [img]smile.gif[/img]
Trying to find balance
Post more info about your entire setup -- what control arms are you running, you have more than one strut brace?
By struts do you mean shocks? What brand / valving?
Lowering springs? How low / what rate
Sway bars are a curious thing. Dirt cheap and easy to install, but that leads many people (yeah, me) to do them before everything else, when in fact experts reccommend doing them after you finalize other stuff. Whatever.
Get a set of 32/19 1LEs. Or get a set of Suspension Techniques 35 and a 1LE 21. Go with poly endlinks at least, and body bushings would be even better. But you better have the tire grip to back all this up, and know that if you go with 32/21s (like many of us), or somehow don't install them right (it's a piece of cake), your car will handle MUCH differently. I installed the 21 rear and ran with it for a while, hellllllo snap oversteer. Just be careful. Go huge up front.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
Pointers:
If you have lowering (stiffer) springs, you have additional antiroll already. Stock bars may be fine. Really big ones will be too much.
Because stiffness changes as the fourth power of the diameter, a 2mm change is really pretty big. It's about twice as big a change on the rear as it is on the front.
To avoid changing the handling balance too much, keep the ratio, front/rear, about the same. If you make a change, make it toward a bigger front/smaller rear. Because of improved front camber, that will affect the balance less than going the other way.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
V6BOB Is there information available to compare roll resistance on various swaybar diamaters and hollow vs solid? thanks
[ December 14, 2002: Message edited by: prdcp97v6 ]</p>97 RS, M5 Y87 (3.42rear, posi, a/c)<br />35mm/25mm solid swaybars, BMR moly STB, alum DS, adjustable panhard bar, GM ZR1 17X9.5 w/275/40 BFG KD\'s, 360lb front & 140/170 rear springs, Koni SA shocks, poly bushings all round. CAI K&H filter, 160 thermostat, Edelbrock cat back, rollbar, pair red competition seat & belts,red carpet & door pannels, redline lubricants all round.
Absolute stiffness is a bear to do because the shape of the connection to the suspension figures into it.
Relative stiffness of two bars that have the same shape is diameter 1 to the fourth power divided by diameter 2 to the fourth power. For hollow bars use outer diameter to the fourth power minus inner diameter (gotta know this) to the fourth power instead.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
I have upgraded to heavy duty (read 1LE)sway bars and found it to be the best mod yet in terms of adding handling stability to the car.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
