Y87 1/4 mile - FirebirdV6.com/CamaroV6.com Message Board
Y87 1/4 mile
This topic is closed.
  • #16
    Re: Y87 1/4 mile
    i had a 97 w68 y87 bird stock i went 15.3 @ 87
    after switching to a 1 piece DS and a home made CAI i went 14.8 @ 92 on street tires. my best mph ever was a 94.xx
    -brandon
    i said I HAD 97 W68 Firebird Y87 they came w/ a 2 piece DS.
    __________________________________
    00 black t/a m6
    Stock Internals=11.81 @ 117 1.59 343hp/349tq
    Cam Only=11.29 @ 120 1.55 418hp/380tq
    http://www.cardomain.com/id/demonicbird00
    [/QUOTE]
    2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
    • #17
      Re: Y87 1/4 mile
      Originally posted by FireBird_Fr3ak
      quoted from 1999 section here http://tech.firebirdv6.com/general.html
      that's wrong, because i definately had to fight a 2-piece when i switched to my aluminum on my '99
      • #18
        Re: Y87 1/4 mile
        Well i have a 1-piece, and it is stock i know it, it even has the little numbers on it. But i have a y87 so who knows, maybe thats was part of the package...
        '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
        '99 Firebird SOLD 1/4 mile 15.4 @ 86
        '66 Ford SOLD
        • #19
          Re: Y87 1/4 mile
          they went from a 2piece DS to a 1 piece in either 98 or 99 i cant remember.
          -brandon
          • #20
            Re: Y87 1/4 mile
            its 99 ive double checked on 3 sites now...
            '66 Ford SOLD
            • #21
              Re: Y87 1/4 mile
              some 99s had the 2 piece and some had the 1 piece. They were in the process of converting over. Some of the overseas cars also had to have the 2 piece for vibrations at high speeds on the highways over there.
              Overall though the alum. driveshaft swap from a 2 piece usually nets .2 in the 1/4
              http://www.bowtiev6.com/
              • #22
                Re: Y87 1/4 mile
                Would it be worth it to swap the steel with alum?
                '66 Ford SOLD
                • #23
                  Re: Y87 1/4 mile
                  some but not as much as 2pc to 1pc. The alum is steel slightly lighter than the steel 1 piece
                  Thing with the steel is that it is stronger than the alum so if you go with some big power in the future, then less chance of snapping it.
                  • #24
                    Re: Y87 1/4 mile
                    The biggest difference in the driveshaft is the weight: less rotational mass = faster car.
                    2 pc...32lbs.
                    1 pc steel....15lbs.
                    1 pc alum....11lbs.
                    1997 Camaro RS A4
                    2006 Chevy Colorado
                    2003 Kawasaki Ninja ZX6-R
                    • #25
                      Re: Y87 1/4 mile
                      the 1 piece steel is definatley more than 15 lbs...I would've guessed in the low 20s...its pretty stout.
                      Shawn<br />2002 Silver W68 Firebird
                      • #26
                        Re: Y87 1/4 mile
                        You are right Shawn, the 1 pc steel is 16 pounds, my bad :p
                        BTW, the alum is 11.5, that was a typo in my last post.
                        http://www.bfranker.badz28.com/fbody/weights.htm
                        1997 Camaro RS A4
                        2006 Chevy Colorado
                        • #27
                          Re: Y87 1/4 mile
                          Hm, it still seemed heavier than that.
                          I have mine at our shop, I'll weigh it.
                          • #28
                            Re: Y87 1/4 mile
                            when i weighed them, my stock 2 piece was 27 lbs. the stock steel from the lt1 was 17lbs and the ls1 ds is 10lbs.
                            • #29
                              Re: Y87 1/4 mile
                              Originally posted by airattack111
                              yawn, y87 is better than not having y87, case closed.
                              Not true. My non-Y87 car came with 3.42 and lsd and would whup Y87 cars. 14.6x with no intake and a LS1 muffler.
                              • #30
                                Re: Y87 1/4 mile
                                you still had to update your car to beat it, id rather have a Y87 than non with 3.42's and LSD. It has the tighter steering and dual exhaust already...
                                And im calling :bs: on a 14.6 with just a muffler and no intake...till i see a slip
                                '66 Ford SOLD
