First time at the track and man am i depressed - FirebirdV6.com/CamaroV6.com Message Board
  • #76
    Re: First time at the track and man am i depressed
    Originally posted by Pewter02Camaro
    I own an '02 3.8 auto with the following mods: ZZP GT1 cam, Flowmaster catback, K&N FIPK, 160 drilled stat, SLP manual fan switch, 3.42 gear.
    OK I see you have it tuned now.. Let me give you a little advice on racing Auto F-Bodies. Before you do exhaust, or head/cam or anything.. You start with Suspension and Transmission. With full suspension and a built tranny with a verter, and LSD (if you don't have one)your car would be faster on stock engine than it is now with the mods and tune. Once the suspension and tranny are right everything else will fall into line.. Also during the entire process practice practice practice... experience pays bigger dividends than you think... OH yeah and get rid of that Flowmaster and get something that flows
    2000 Firebird.. Whisper lid, Custom exhaust, FRA mod, MSD Coil packs, MSD wires, TCI 3000 stall verter, TSP mail order tune. No times as of yet waiting for the track to open
    • #77
      :rock: ^^^ agreed!
      The only thing I disagree with is I would get a full exhaust, lid, mail order tune THEN go for suspension and trans. Then start again with things like heads, cam (then dyno tune), spray etc :naughty: Realistically, most V6's are not garage queens and most drivers (like me) want some mods that can show on the highway and daily driving, as well as at the track. Just my $.02
      edit: Limited slip should be the FIRST mod for ANY F body that is not factory equipped. Even running on bald tires.
      • #78
        I didn't really get a good run all day. Had at least one thing go wrong on each pass as stated alomg with the new times. Once i get rid of the wheel spin i should be able to get my 60 foot times down. Gonna do a longer burnout in the water box next time.
        if you are on street tires, do NOT do a burnout in the water box.. this will piss people off... water gets in the treads, drips all over the launch point, slicking up the track.. this could be part of the reason you are spinning so much on launch as well
        2000 Bright Red Camaro 3800 V6, A4, LSD, 3.42<br />Whisper lid, K&N, American Thunder Catback, Wings West GFX, Billet Grill<br /><br /> <a href=\"http://www.mfba.org\" target=\"_blank\">http://www.mfba.org</a> <br /> <a href=\"http://home.comcast.net/~thontor/camaro/\" target=\"_blank\">http://home.comcast.net/~thontor/camaro/</a>
        • #79
          We should sticky that ^^^ That IS the reason his 60 is so low. No doubt. Just clean the tires off, light em up real fast after the wetbox.
          • #80
            just to add one thing... dont even drive through the water if you are on street tires, there is usually room to drive around the water, use it..
            • #81
              also street tires dont get much sticker when they have been heated up.
              -Y87
              Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
              • #82
                ^ actually, they do. Tire compound gets softer when heated up. Period. The benefit to burning out on street tires is also to clean them off. As previously stated.
                • #83
                  true, but they don't benefit nearly as much as drag tires because there is a lot less rubber actually contacting the pavement...
                  • #84
                    also true, but the comparison was between cold street tires and warm street tires. :naughty:
                    • #85
                      ...is not that great of a difference, especially if the car has any definition of power. Street tires are still street tires, warm or whatever
                      • #86
                        Yes there is a difference. Now stop arguing this or some people may actually believe you. Theres enough ignorance on this particular board as it is.
                        • #87
                          Look at how the OP describes his car.
                          Heating up street tires may work for a lightly-modded 3.4 or a stock 3.8, but with the numbers he's putting down, the compound that street tires are made up of simply cannot handle a hard launch, period, indent paragraph.
                          The only thing that will net him a sub-2.0X 60' is drag radials. They don't have to be all out slicks, but the OP's moved far beyond what street tires can offer him.
                          Then do something to change that. Here's a hint: crying to me ain't it.
                          • #88
                            I find street tires slightly warm "aka do a slight burnout in cold weather" hooks way better than doing no burnout.... maybe that's just me
                            Camaro V6 - 14.3 @ 96mph
                            Camaro SS - cam/boltons/m6/tune
                            http://www.crfhq.com
                            • #89
                              To bad the season is over otherwise i would have had more time to practice.
                              It doesn't seem to have matter if i heated them up or not i still had wheel spin either way. I avoided the water box and that helped. I am probobly gonna try to pick up some DR's for next season if i can without spending to much money.
                              Daily: '02 Black Yukon Denali
                              Toy: '06 Torrid Red GTO
                              Gone: '07 Charcoal Yamaha R6
                              Gone: Ex-wife, lol
                              • #90
                                Warm street tires are better than cold street tires.
                                A full on burnout with them is pointless though because the compound is not meant to get soft and tacky like a drag radial does.
                                Shawn<br />2002 Silver W68 Firebird
