tires - FirebirdV6.com/CamaroV6.com Message Board
tires
  • tires
    ok i have 235-55-r16 tires on my car and i was looking at the formula tires that r 245-50-r16 wat i wanna know its wat the diff? is the tire taller? or wider or wat. can anybody tell me wats the diff is?
    Re: tires
    235 is the width of the tire in mm, 55 is the height of the tire sidewall in mm, and the lettering with r16 is the speed rating of the tread for that tire on a 16 inch rim.
    that formula tire will be a little wider (245>235), and slightly less profile than your existing tires (50<55).
    start researching on discounttiredirect.com
    pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
    gone in body, but not in spirit
      Re: tires
      You are correct in the first number being the width in mm, but the second number is an aspect ratio. The sidewall of the 235 is 55% as tall as the tire is wide (approx 129mm). Then 50% on the 245 (approx 123mm). For ex: 245/50r16 would be taller than a 245/40r16, and a 255/50r16 would be taller and wider than a 245/50r16.
        Re: tires
        consider me corrected. got in a hurry and put mm. good call sir.
          Re: tires
          that r actually means its a radial tire. when reading the size of a tire and you look at the next set of numbers after the rim size for example...86T..93H...those are speed ratings. every tire sales website has a chart what each letter stands for what the tire is rated at
            Re: tires
            i didn't say the "r" was the tread rating, i said the lettering with it, as in 275/40/17zr, which is mine.
              Re: tires
              "z" would indicate the speed rating of your tire.... the "r" still stands for radial
                Re: tires
                once again, i didn't say the "R" stands for the speed rating, i put how it appears on my actual tires for reference. i'm well aware that i have Z-rated radial tires, thus Zr, let it go.
                clearly R stands for radial, and in my initial reply i put, "the lettering with r16 is the speed rating of the tread for that tire on a 16 inch rim".
                find something else to pick apart. the OP has his answer.
                  Re: tires
                  ballermaro is and was correct...
                  Custom interior...
                  TEAM NoVa
                    Re: tires
                    Hey Baller.. Actually that B in your name stands for B!tch, which is what everyone else here is trying to make you. Don't worry, T-Mill and myself will back ya up. :D
                    TEAM C6V6
                      Re: tires
                      lol they can try but it ain't gonna happen ;) thanks for the backup tho fellas! i would hope my fellow c6v6 teammates would have my back on explaining something as simple as tires haha.
                      but apparently i cant even read the profile lettering on my own tires, bc they're clearly wrong lol :p u have nittos too blizzard, you probably should go study them!
                        Re: tires
                        I'll uh, get right on that.
                        TEAM C6V6
                          Re: tires
                          your 275/40/17 zr tire is not a z rated tire, go look its a "w" speed rating. look really closely all around the tire, you will see a 98w, or 98Y which is your speed rating.
                          Team NoVa
                            Re: tires
                            my lord i'm tired of this tread...
                            http://www.discounttire.com/dtcs/tir...98052&pc=40139
                            my exact Z RATED TIRE
                            z= 149 and over, however, the 89w indicates that the tire is capable of safely running up to 168mph.
                            LEARN:
                            Speed Rating
                            The speed rating of a tire is based on U.S. Government standards for reaching and sustaining a specified speed. Typically, a tire with a higher speed rating results in better handling. Speed ratings are determined via laboratory tests that simulate road performance at various speeds.
                            Below is a list of speed ratings along with the corresponding speeds they represent. Remember that the speeds listed are test speeds and not recommended speeds. Speed ratings apply only to the tire itself, and not to a particular vehicle. Putting a tire rated for a certain speed on a vehicle does not mean that the vehicle can be safely operated at the tire's rated speed.
                            • Q Up to 100mph
                            • R Up to 106mph
                            • S Up to 112mph
                            • T Up to 118mph
                            • U Up to 124mph
                            • H Up to 130mph
                            • V Up to 149mph
                            • W Up to 168mph
                            • Y Up to 186mph
                            • Z 149mph and over
                            If a listed speed rating contains two letters (such as VR), the first letter represents the speed rating and the second letter (R) indicates that it is a radial tire.
                              Re: tires
                              ^straight from the source.
                              this is getting ridiculous---by next week someone will try to tell me i dont even have tires on my car...i didn't realize this was an "argue for the hell of it" thread disguised as tires.
                              i'm done arguing about what is and is not on my car.
