'84 Rear end - FirebirdV6.com/CamaroV6.com Message Board
'84 Rear end
  • '84 Rear end
    Ok need a little help my uncle has a 1984 Z28 with the 5.0L H.O. engine. he siad the diff locked up (the tires wont spin) on him going to work the other day and all the fluid leaked out so something big happened. I have not got a chance to look at it yet but was trying to find out the diff spec's the dealer said its too old to give them the vin number for info. from my understanding there were 2 types of axles used a chevy and borg warner also 4 gear ratio's as well 3.08,3.23.3.73,3.42
    How can i find out which one he has? Thanks
    1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
    Re: '84 Rear end
    Take it apart.
      Re: '84 Rear end
      my suggestion is to join a 3rd gen website, and tell them about the car, and they could narrow everything down for you.
      are there no rpo codes that could give you a clue?
        Re: '84 Rear end
        ya looks like im just gonna have to take it apart next weekend hopefully there will be a tag still on the rear end with info on it. just thought i would try here first in case someone had input on it since the dealer was no help.
        Thanks anyways guys.
          Re: '84 Rear end
          NO tag on GM rears unless it says " Limited slip differential fluid only". If it's the Dana You'll know as soon as you look at the cover.
            Re: '84 Rear end
            http://www.thirdgen.org/1984-chevy-camaro
            I haven't looked at my haynes or 85 service manual, but if the rear is anything like the 2nd gens, there will be some numbers on the pass side of the axle iirc, that can be used to determine what type it is. also need to know what tranny he has for ratio
            2013 Ram 1500 Big Horn
            94 comero 3.4
              Re: '84 Rear end
              I'm betting he has the 3.23 rear.
              Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
                Re: '84 Rear end
                ok thanks guys will post back when i look into it. and again not sure what auto tranny he has in it he told me when he bought it new that he had to take it back and have the tranny replaced with a stronger one cause the old one kept blowing. there again guess well see whats in it when it comes apart
                thanks again
                  Still trying to find oil leak
                  3 days ago
                  Getting some work done on my truck
