Heres a little turbo that im putting on my car.(been checked out and doesnt need rebuilt, only 40k miles on the turbo) Just a ar. 48. Small but im not looking for crazy boost. The stock wastgate is set to 7psi. So ive got alot of work to do with the exhaust routing and tuning. I think ive decided to go with the $59 mask and bin to tune with, with a 3 bar map, so i can meter and compinsate for the boost, also 22# injectors, so theres only room for about 200-250 hp(turbo will only efficently run up to 16psi/275Hp) but when your starting with 150-160hp thats a big gain. I cant afford the big # injectors. So far i have 0 dollars in this project. So this is the tightest budget build possible. The main costs is going to be for the WB o2 sensor kit and the 3 bar map sensor. Ill update with pics as the progress continues.
