Two questions, the first, I asked in the Gen. Tech section, but it's kinda' busy in there, plus this pertains more to the 3rd gen bodies. A.) How hard would it be to replace the rear oil seal on a 3.1L V6, and B.) for the few of you who may still have the stock airbox in your 3.1L V6's, on the round cannister, there's something plugged into the cannister. What is that? I apologize, 'cuz I know these may be dumb questions, but I wanna' learn, and how else, but to ask questions.
Rear oil seal and stock airbox
1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"Tags: None
<blockquote>quote:</font><hr>Originally posted by Colin:
B.) for the few of you who may still have the stock airbox in your 3.1L V6's, on the round cannister, there's something plugged into the cannister. What is that?<hr></blockquote>
That is the Oxygen sensor. If you plan installing a cold air intake, don't forget to drill a hole in it so you can insert the sensor in the new intake.
I apologize, 'cuz I know these may be dumb questions, but I wanna' learn, and how else, but to ask questions.<hr></blockquote>
Don't worry about it, it's not a dumb question, that's what this board it for. If you would have asked me the last question before I installed my CAI, I wouldn't have known the answer either.<a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1991 Firebird - 3.1L V6</a> with custom K&N CAI, Flowmaster, Sony CD, MTX 4-ch amp, 2 MTX 10\" subs, Sony & Polk speakers, Eagle Wheels<br /><br /><a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1997 Firebird Trans Am</a> with T-Tops, Panasonic CD, Alpine Speakers, MagnaFlow Exhaust, and Lingenfelter CAI.
the thing in the air box is the air temp sensor, the o2 is in the exhaust pipe right behind the T-connection.
edit: dammmit, this procedure is for 84 models
according to haynes:
1. remove oil pan & pump (see previos sections for full details)
2. remove cap
3. pry lower half of seal from bearing
4. to remove upper half, use punch & hammer to roll seal around ****DO NOT hit crankshaft****
5. remove all sealant & foriegn material
6. apply rtv sealant to outer surface of NEW seal **DO NOT get sealant on crank side of seal*****
7. use installation tool to guide new seal into place
8. istall big lipp front engine, little lipp rear
9. rtv the lower seal& install on lower cap
10. tighten & torque to spec
11. re-install pump & pan.
edit: for 85 & up, "REMOVE TRANSMISSION"is a step beacause we have a 1 piece rear main.
for anymore info, buy the book [img]tongue.gif[/img] ;) :mad:
[ January 13, 2002: Message edited by: 2.8 slow to go ]</p>1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
also, shoulda asked in the V6 section of third gen, too many 8 bangers trollin around there ;)
94 comero 3.4
Okay, the O2 sensor/air-temp sensor........either way, all you have to do is drill a hole for it to go in?? And the rear seal--'85 and up has to drop the tranny??? If so. . .d**n!!!1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
i meant to add in there, that i figured the O2 sensor was more around the exhaust system, 'cuz that's the way it is on most cars, no matter what.
thanks again.1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
oops, sorry about that. I have heard the sensor that goes in the airbox being called the oxygen sensor on this board and others, but upon closer research, 2.8 is right.<a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1991 Firebird - 3.1L V6</a> with custom K&N CAI, Flowmaster, Sony CD, MTX 4-ch amp, 2 MTX 10\" subs, Sony & Polk speakers, Eagle Wheels<br /><br /><a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1997 Firebird Trans Am</a> with T-Tops, Panasonic CD, Alpine Speakers, MagnaFlow Exhaust, and Lingenfelter CAI.
