Newbee here, Hello all I had my car for about 5 years. And I love every day of it! here's my prob.
I would like to beef up my 2.8 and I have no clue as of where to look.
Thanx to all who reply!
<a href=\"http://www.fortunecity.com/uproar/winners/213\" target=\"_blank\">Craft-Matic-Man\'s Web Site</a><p>\"I Was A Wash In A Sea Of Poo\"<br />Johnny Knoxvill / Jackass<p>\"Can You Walk Like A Pimp, Is Your Bizkit Limp\"<br />Whity Ford / Faith Remix
If you are looking to get some real power out of your car, then the 3.4 swap is probably the easiest engine to swap in, as 2.8 suggests.
If you don't have a lot of money to spend right now, you might want to consider the basics first, such as an exhaust (I like the Flowmaster 80 series) and custom made cai, both of which can be used when you decide to upgrade to a 3.4.
<a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1991 Firebird - 3.1L V6</a> with custom K&N CAI, Flowmaster, Sony CD, MTX 4-ch amp, 2 MTX 10\" subs, Sony & Polk speakers, Eagle Wheels<br /><br /><a href=\"http://home1.gte.net/res07t9s/index.html\" target=\"_blank\">My 1997 Firebird Trans Am</a> with T-Tops, Panasonic CD, Alpine Speakers, MagnaFlow Exhaust, and Lingenfelter CAI.
It should, since the TH700R4 is the nonelectric version of the 4L60E which is used in the 4th gens with a 3.4L. I'm not a trans expert, but I think it should work.
Sweet! But can i keep my fule injection? [img]graemlins/burnout.gif[/img]
the 4.3 is a 3/4 sbc. 90* engine. The 2.8/3.1/3.4 is a 60* engine. different tranny bellhousings, different manifolds, same oil filter, different heads.
2013 Ram 1500 Big Horn
94 comero 3.4
Yes. From what I have been told about the swap you use your injection system from the 2.8/3.1 on the 3.4. As for the tranny, yes it bolts right up as well since they are both 60*s.
~Josh~
1992 Firebird 3.1<br />16.61@80.70<br />CCAI With K&N Filter<br />DynoMax Cat-Back Exhaust<br />KYBs Shocks and Struts<br />Hotchkis Performance Coils<br />Everything else stock for now!!!
heres a good list of mods without getting a 3.4. but if you got a 3.4 you would need bigger fuel injecters.
compcams 2030
1.6 fullroller rockers
custom 2.5 inch exhaust
high flow cat converter
home made cold air induction or slp enginering has 2 cai systems that will work
60mm throttlebody stock is 50mm
port and polish intake manifold
msd 6a ignition box and coil
8mm spark plug wires or larger i like accel 8.8
bosch platinum 4+ spark plugs
transgo shift kit
a higher stall converter
3.42 gearing...
there are manythings that we can do to improve upon our cars it just depends on how deep your pockets are.
check out thunderracing.com for a good ramair hood and good suspension mods. they gave pretty good prices too.
-Adam
Red 1990 Firebird:125,000 miles <BR>kn air filter<BR>bosch +4 platinum spark plugs<BR>accel 8.8mm wires <BR>700-r4<BR>Mobil 1 synthetic 10w30 <BR>z-max addatives (wow)<BR>Trans Am Hood W/Black Vents<BR>BF Goodrich 235/60R15<BR>Aftermarket muffler-dual single tips<BR>the rest of the exhaust?
