?'s about swapping a 350 in a Berlinetta. - FirebirdV6.com/CamaroV6.com Message Board
  • ?'s about swapping a 350 in a Berlinetta.
    Will a 350 drop right in a Berlinetta with different moter mounts or what needs to be done.
    Arctic White \'02 Camaro<br />3.8, 5spd.
    new tranny, new mounts, new tach, new front springs, engine harness, if emissionas isn't a problem, go w/carb set up. easiest to swap in. TV or kickdown cable, depending on tranny. AFPR, exhaust system, headers aplenty though.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Wouldn't you just need to swap the blocks out?
      edit: eh, I'm a dummy. I forgot that not all Berlinettas came with a 305. I recently picked an '85 up for a little over a grand. T-tops, carb 305, power (fully working) interior, and a straight body. Not a bad deal. I'd just have to swap out the 305 block and maybe a few other things, right?
      As for a v6, or 4 banger, swap, it would be the typical painfull procedure. Motor mounts, new tranny, new driveshaft?, tranny mounts?, etc.
      [ June 29, 2002: Message edited by: Firebird Type R ]</p>
