If I have a '92 Firebird w/a 3.1L engine, 700R4 tranny, can I do a straight swap from that to a trusted used TPI 5.0L that has the engine, TPI setup, computer and wiring?
Swapping to 5.0L
Swapping to 5.0L
1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"Tags: None
Yeah, I asked a while back about a swap, and someone said that I'd have to switch trannys, but I've noticed a lot of 305's and 350's mated to a 700R4. What's the deal with the radiator though?1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
Well, you still have to change tranny's. We have a 60* motor. AS for the radiator, it is a bigger engine the 3.1.
~Josh~1992 Firebird 3.1<br />16.61@80.70<br />CCAI With K&N Filter<br />DynoMax Cat-Back Exhaust<br />KYBs Shocks and Struts<br />Hotchkis Performance Coils<br />Everything else stock for now!!!
you need a bigger radiotor to handle the cooling of a bigger motor and i believe only the bell housing is different between the v6 and v8 automatic trannyRed 1990 Firebird:125,000 miles <BR>kn air filter<BR>bosch +4 platinum spark plugs<BR>accel 8.8mm wires <BR>700-r4<BR>Mobil 1 synthetic 10w30 <BR>z-max addatives (wow)<BR>Trans Am Hood W/Black Vents<BR>BF Goodrich 235/60R15<BR>Aftermarket muffler-dual single tips<BR>the rest of the exhaust?
and new engine harness, and tach(if you allready have one), & e-check exemption. Don't forget all the accessories that go w/the V8. & if you do go ahead, use the 350, more power available per mod.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
man i wish i didnt have emissions checks here ....... :( hell what i would do in your situation is pick up a nice carbed 350 . ditch the computer slap in a turbo 350 trans and your set [img]smile.gif[/img] of course , i wouldnt do any of this if it were my daily driver1987 z28 . lg4 305 . edelbrock performer intake , 600 cfm performer carb , all smog equip gone . gutted cat . slp headers with y/pipe and cat back , mild street cam . pocket ported heads<p>14.1@97 mph w/2.1 60\' .
re-read your first post. since you have the motor, harness & computer, spend the $$ & get a tranny w/the correct bellhousing & a service manual. This will provide you w/all the neccessary wiring diagrams. Relocate motor mounts on frame, buy new V8 mounts remember. then think about headers & what not.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
